Jochen_145 wrote: |
| ...is the break contact only available for the Passat? |
No, this applies to all VAG models. Imagine it as a wire embedded within the brake pad material. As the pad wears down over time, this wire is gradually ground away and eventually severed – this is what's known as a "break contact," because it essentially breaks.
Jochen_145 wrote: |
| I haven't taken a close look at the contact point on my Seat yet, but with Alfa, it was the case that there was only one wire going to the pad. This wire would then be pulled to the metal casing when worn, and the light would come on. |
In VAG systems, it's the opposite. By default, there is a ground connection (warning light OFF). When the contact is broken, the ground connection is lost (warning light ON).
Jochen_145 wrote: |
My question arises because an acquaintance installed contact-free brake pads in his A3 and short-circuited the contact on the connector. Unfortunately, the warning light is now always illuminated.
This is likely not the case with a break contact, as the circuit is not interrupted. |
Then he probably connected something incorrectly.
