Timing Belt Cracked: AVF Engine - Repair?
TDI-PanTheR
Post24-08-2006, 21:15    Subject: Timing Belt Cracked: AVF Engine - Repair? Quote
My parents drive a 2003 Passat with an AVF engine.
For a few days, my parents have been complaining about very high fuel consumption. Well, there was also a huge stain of diesel icon_smile.gif underneath the car.
'The drain plug on the fuel filter had broken off... When I discovered the problem causing the high fuel consumption, I jokingly decided to take a look under the timing belt cover to see what the timing belt looked like.'
I was very shocked to see how worn the timing belt is. The car has only 70,000 km on it. I also don't think it would last another 20,000 km.
Has this happened before, or what could be the reason why it's already so cracked and porous after such a 'short' time?
panther
Translated on 04-10-2026, 22:02.
bloesch
Post24-08-2006, 22:30    Subject: Timing Belt Cracked: AVF Engine - Repair? Quote
hi.
There's a solution for the filter screw issue... a protective cover (I don't know what it looks like) will be installed. The VW dealer should check their "HST" (presumably a technical manual or database).
Translated on 04-10-2026, 22:03.
Herr Antje
Post25-08-2006, 5:40    Subject: Timing Belt Cracked: AVF Engine - Repair? Quote
Perhaps the timing belt is too old, which is less likely, or maybe a pulley is running too heavily. I would replace it.
Aktuell:
- G3 VR6 '93 128 kW, MKB: AAA
Translated on 04-10-2026, 22:04.
Nebelwerfer_TDI
Post25-08-2006, 10:30    Subject: Timing Belt Cracked: AVF Engine - Repair? Quote
If it develops cracks, it should be replaced immediately. The best option is to either take it to a workshop or replace it yourself.
'Material defect in the rubber compound?! Mine is already 8 years old and still looks good.'
'Our fire truck is already 23 years old, but it looks brand new - thankfully, it has an automatic clutch (otherwise, the work would fall on me).'
delvos
Post01-09-2006, 10:04    Subject: Timing Belt Cracked: AVF Engine - Repair? Quote
This is a problem that is known to VW. If the car is less than 3 years (or was it 4?) old, you can get a timing belt replacement, including everything, sponsored by VW. In my case, the timing belt was cracked after 60,000 km (30,000 km before the scheduled replacement interval). Now there is peace of mind until 150,000 km, hopefully icon_smile.gif.
The new belt that's being installed is the one for the 120,000 km service interval.
It also looks completely different from the old one. The old ZR had a rubber coating on the tread (which became/will become cracked), while the new one has a kind of fabric applied to the tread.
Translated on 04-10-2026, 22:06.
TDI-PanTheR
Post01-09-2006, 18:05    Subject: Timing Belt Cracked: AVF Engine - Repair? Quote
Hmm, but it's likely that all the inspections were carried out at a VW service center, right?
A friend of mine replaced it at a local repair shop. The car is from January 2003.
panther
Translated on 04-10-2026, 22:07.
No new posts Documentary: Transporter 7D, Timing belt failure Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Timing Belt Issue: A3 (98+) - Not Centered on ESP Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Cracked Timing Belt: Causes & Replacement Diesel Engine Technology
No new posts Timing Belt: Replacement & Repair Guide Diesel Engine Technology
No new posts Timing Belt: Replacement & Cost (AVB) Diesel Engine Technology
No new posts Timing Belt AJM Diesel Engine Technology
