Probleme mit 1,9AFN | Posts 32+
Go to page: Previous  1, 2, 3
Post25-08-2006, 9:22    Subject: Quote
3BVari wrote:
The VTG (variable transmission gear) can be moved about 1 cm back and forth without the can attached. When I disconnect the can, the lever is in its resting position, which is open.
Okay, but how can you be sure that the exhaust gases flowing backwards won't push the freely moving VTG (variable geometry turbine) towards the engine during operation?
To rule that out, I would somehow secure the valve travel gear (VTG) in the open position, even without the can.
Then the LD (lateral deviation) should not actually rise too high while driving.
Translated on 01-08-2026, 5:21.
3BVari
Karma: +1 / -1   Thank you, like it!
Post25-08-2006, 10:55    Subject: Quote
Hello.
I hadn't even thought of that yet...
"If I were to tighten the lock nut all the way against the housing, perhaps that would prevent it from loosening..." That might be a possible solution.
I'll try that out.
Best regards.
Translated on 01-08-2026, 5:22.
3BVari
Post02-09-2006, 19:36    Subject: Quote
Hello!
Okay, I used VCDS to log some data, and the boost pressure is increasing to about 2560 mbar, even though nothing has been disconnected! Then, the car goes into limp mode, at the latest around 120 km/h... icon_sad.gif
The electromagnetic valves have all been replaced and are now in order. icon_sad.gif
Is there anyone in Hanover who is a skilled diesel mechanic and willing to offer their services?
Best regards.
Translated on 01-08-2026, 5:23.
No new posts AGR Problems: 1.4 16V Gasoline Engine Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Cruise Control Installation Problems Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document A2 8Z0 MJ 2002, Problems with the Main Control P... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ASU Issues: Troubleshooting and Solutions Diesel Engine Technology
No new posts 2.5 TDI AAT Problems: Common Issues & Fixes Diesel Engine Technology
No new posts ABS Problems: Causes and Solutions On-Board Diagnostics (OBD)
No new posts ALE: Troubleshooting GRA Issues in MKB Diesel Engine Technology
