CAN Gateway A3 8PA: Incorrect Coding?
pschaefer
Post01-08-2006, 11:55    Subject: CAN Gateway A3 8PA: Incorrect Coding? Quote
Hello!
After I installed the RNS-E navigation system and the Audi phone module, my CAN gateway says...
Code:
Adresse 19: CAN Gateway
   Steuergerät: 1K0 907 530 G
   Komponente: J533__Gateway   H10 0140
   Kodierung: 7F3F0BC207002102
   Werkstattcode: WSC 06314
1 Fehler gefunden:
01044 - Steuergerät falsch codiert
            000 -  -
Well, it wasn't like that before. Remaining encodings:
Code:
Adresse 37: Navigation
   Steuergerät: 8P0 035 192 A
   Komponente: RNS-E HIGH EU   H70 0460
   Kodierung: 0205715
   Werkstattcode: WSC 76091
Code:
Adresse 77: Telefon
   Steuergerät: 8P0 862 335 M
   Komponente: FSE_255x BT     H21 0200
   Kodierung: 0001411
   Werkstattcode: WSC 00000
I only added to byte 3, bit 7 of the CAN gateway encoding. Do I need to set the bit for "navigation" instead of, or in addition to, the bit for "radio"?
Was mir auch noch aufgefallen ist: Über das MuFuLe kann ich die Telefon-Adressliste sehen (nach Druck "Mode" erscheint die Liste im FIS); im Navi-Tel-Menü kommt aber nix. Momentan ist die Handy-Halterung aber noch nicht angeschlossen, d.h. z.Zt. BBluetooth only.
P.S.: I would not recommend retrofitting the original hands-free system in the A3 8PA to anyone! That's really a job for someone who has "killed" their mother and father!!! icon_twisted.gif
Thank you & Best regards.
Peter.
*Die Fahrbahn ist ein graues Band, weisse Streifen, grĂźner Rand*
Translated on 17-09-2026, 8:24.
pschaefer
dieselschrauber likes this.
Post01-08-2006, 21:00    Subject: CAN Gateway A3 8PA: Incorrect Coding? Quote
Short feedback: I figured it out now.
    * When using the CAN gateway, radio and navigation must be coded.
    * For the telephone TCU, in addition to the encoding from OpenODB.org, a "1" must be encoded before it (so, for me, it's 00101411 instead of 0001411).
Maybe this will help someone in the future.
Translated on 17-09-2026, 8:25.
Udo_G
Post15-09-2006, 9:04    Subject: CAN Gateway A3 8PA: Incorrect Coding? Quote
Hello!
Did you have a NaviPlus system installed before, or just a regular radio?
I'm experiencing a similar problem.
While coding (THANK YOU B. icon_biggrin.gif) my RNS-E in conjunction with the NOKIA 6091 integrated system, the following "error" occurred:
STG 56 / 07 was programmed with the code 0301315, which resulted in the following error:
[Dead link]
With this setting, when I press the RNS-E/TEL button, I get the message: "Please use a mobile phone!" However, as mentioned above, I am experiencing the error.
... when using the coding (xxxx?xx) 0301415 or 0301715, it does NOT cause any errors in the control unit. However, when I press the RNS-E/TEL button, I get the message "No phone available," and I am also experiencing problems with the Nokia 6091 (e.g., in conjunction with the MFL).
The strange thing is, I can't program the telephone system (STG 77). I can change the codes, but unfortunately, I can't save them.
[Dead link]
Does anyone know how to fix this error?
"Thank you!"
Udo.
Translated on 17-09-2026, 8:27.
vagtuning
Post15-09-2006, 12:27    Subject: CAN Gateway A3 8PA: Incorrect Coding? Quote
I'm not surprised - the fixed installation of the Nokia device can't communicate with the RNS-E system. You need the UHV for that, as it's the only device that can.
Translated on 17-09-2026, 8:29.
Udo_G
Post15-09-2006, 12:31    Subject: CAN Gateway A3 8PA: Incorrect Coding? Quote
vagtuning wrote:
I'm not surprised - the built-in Nokia system cannot communicate with the RNS-E either; you need the UHV for that, as it's the only one that can.
Hello!
Wer klärt mich mal auf? What is UHV?
Udo.
Translated on 17-09-2026, 8:30.
vagtuning
Post15-09-2006, 12:44    Subject: CAN Gateway A3 8PA: Incorrect Coding? Quote
Universal phone preparation - which also works with the 8P.
Control unit part number: ALWAYS 8P0 862 335 xx (xx = corresponding index).
Udo_G
Post15-09-2006, 12:50    Subject: CAN Gateway A3 8PA: Incorrect Coding? Quote
Thank you for the information. But will simply replacing the control unit with a UHV be sufficient? Will my Nokia 6091 then be able to communicate with the new control unit and the RNS-E?
Udo.
Translated on 17-09-2026, 8:31.
vagtuning
Post15-09-2006, 17:31    Subject: CAN Gateway A3 8PA: Incorrect Coding? Quote
No, it's either a fixed installation OR a universal head unit (UHV), and it needs to be connected to the RNS-E.
Neither option is possible!
No new posts Documentary: Octavia 1 / Golf IV fuel gauge malfunction Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Control: 77 incorrectly encoded, FSE 5K0 035 730 E Electrical Systems, Vehicle Electronics, Multimedia
No new posts A3 8L 1.8T Quattro: Incorrect ABS Coding On-Board Diagnostics (OBD)
No new posts A3 8P Alarm: Gateway Issues & Error Solutions On-Board Diagnostics (OBD)
No new posts Passat 3C: Gateway Replacement Guide On-Board Diagnostics (OBD)
