Document: Passat, Model Year 2000, Window Seal is Raised/Not Seating Properly (Solution)
Michael II
Post12-12-2002, 17:44    Subject: Document: Passat, Model Year 2000, Window Seal is Raised/Not Seating Properly Quote
The outer window seals on the front and rear doors are raised in the middle area.
Affected vehicle identification numbers:
Until 06/2001, 3B2E085000.
Until 06/2001, 3B2P070000.
Cause:
Insufficient fixation.
Solution:
To remedy the issue, install a retaining clip (part number: 3B0 837 073 A) onto the door flange of the outer window seal.
Front door: 200 mm from the front window frame.
Rear door: 350 mm from the front window guide.
Tschüss
Michael II
Ratings - Document: Passat, Model Year 2000, Window Seal is Raised/Not Seating Properly
No new posts Document Passat, Model Year 2000, Brakes Stuck Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat 2000: Rear Brake Noise Troubleshooting Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat 2000: Sun Visor Light Repair Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi 80 B4: High Front - Troubleshooting Guide Transmission, Chassis, Body & Interior
No new posts OBD2 Scanner for VW Passat 2000 PD Diesel Engine Technology
No new posts Passat Variant 2000: 130 HP Specs & Info Diesel Engine Technology
No new posts TDI Passat: High Smoke Value in Emission Test Diesel Engine Technology
