Loch im Kolben | Posts 32+
Go to page: Previous  1, 2, 3
Roadrunner505
Karma: +7 / -6   Thank you, like it!
Post16-06-2006, 17:06    Subject: Quote
BM wrote:
I also have a picture like that to offer. This is the third piston from my 1Z/AHU
Yeah, it seems like it's always the same story.
It would be interesting to know under what load conditions – whether it was during city driving, country road driving, or highway driving – the piston failed.
The 1Z, which I was talking about, happened while I was driving at full speed on the highway.
Yep, speedometer reading 195 on the A7 icon_rolleyes.gif. But, you can't really say the engine wasn't warm - I had already driven 300km.
Translated on 06-09-2026, 0:45.
Nebelwerfer_TDI
Post19-06-2006, 7:50    Subject: Quote
Did you still have the original nozzles in? The beams probably wouldn't have been aligned correctly anymore, not to mention the atomization icon_rolleyes.gif.
The patterns of the jet streams are asymmetrical. Where the crack is, the two patterns are very close together when compared to the others.
Translated on 06-09-2026, 0:46.
mullemaus
Post22-06-2006, 22:54    Subject: Quote
Believe me, I've known this engine for over 10 years.
hihi, how does that work? The AJM wasn't even released until the end of 98 icon_lol.gif.
Just kidding,
and therefore, the engine sucks in an oil amount equivalent to a shot glass and becomes a self-runner,
Does this amount of oil not distribute itself within the intercooler system, and is it then fed to the engine 'slowly'? - After all, the intercooler has a large internal surface area that can temporarily bind a certain amount of oil on its surface........I've seen engines where oil has dripped out of the intercooler hoses after being removed (!) and they ran perfectly normally.
We had icon_rolleyes.gif approximately 2 liters distributed in the system on Monday. When removing the coolant reservoir, it was actually pouring out. It wasn't a gradual leak; the damage was noticed, and the car was stopped in time. But it seems like it was very close to failing. It's a driving school A3 with around 400,000 kilometers on the odometer. icon_wink.gif I think they won't be able to break the new turbo. icon_wink.gif
Translated on 06-09-2026, 0:48.
Nebelwerfer_TDI
Post23-06-2006, 10:14    Subject: Quote
'@mulle: It might have been because the FS vehicles are mostly operated in the lower speed and load range, which allowed the oil to accumulate and not be immediately carried away... or only enough oil was carried away that a self-accelerating condition (increasing speed -> more air -> more oil -> further increasing speed) couldn't develop.'
What kind of new turbocharger did you install? A GT20?
Translated on 06-09-2026, 0:49.
Holger247
Post26-06-2006, 10:01    Subject: Quote
So, is the crankcase ventilation system a potential weak point in all TDI engines, and is it responsible for many engine failures?
It would be interesting to see if cleaning can prevent sticking. Has anyone looked into this before?
GIV - 98 - ALH
Touran 5T 2.0 TDI
Translated on 06-09-2026, 0:50.
Klemmi
Post24-09-2006, 11:16    Subject: Engine Failure: Causes, Repair & Prevention Quote
Hello everyone, as far as I know, engine damage in Pumpe-Düse engines is a recurring problem across the entire range of VAG products, such as the Sharan, Galaxy, etc. (take a look at the Sharan, Galaxy, and Alhambra forums). This is especially problematic for engines that have been chipped (tuned). It's related to thermal issues, as you can see on page 8, which is particularly interesting.
http://www.msi-motor-service.de/download/kolbenschaeden/d/kos_verbrennungsstoerungen_de_web.pdf
Jürgen
EDIT by Guste100: Link corrected.
Translated on 06-09-2026, 0:51.
No new posts Piston hole at cylinder 1 Diesel Engine Technology
No new posts Piston Hole: Causes and Solutions Diesel Engine Technology
No new posts AWX Piston Damage: AVF Engine Replacement On-Board Diagnostics (OBD)
No new posts ALH Clutch Housing Hole - Location & Repair Diesel Engine Technology
