Leistungsmangel 96kw Ibiza (ASZ) | Posts 32+
Go to page: Previous  1, 2, 3
sik
Post26-09-2006, 19:09    Subject: Quote
Quick update: I finally had time today to take a closer look at everything, so I removed the fog lights and grilles...
Result: The lower control arm is actually quite dirty, so I'm going to remove the front bumper tomorrow to completely clean it.
Then I will replace all the seals that are within reach (unfortunately, I only received 3 from the dealer; the price is 10€ for 3 seals and 3 metal clips icon_eek.gif).
When the grill guards and fog lights are installed, the airflow to the LLK (low-level cooling) is significantly improved. With the grill guards and fog lights, only about 1/3 of the area is exposed. In the future, I will also remove the fog lights when I change to summer tires, as I unfortunately need them more often in the winter.
Jedoch gibt es keien passenden Grill um ohne Nebler zu fahren, wie zb. Ulf has it.
All the available grills are either fitted with the hole for the mister or have that spot closed off. Unfortunately, this isn't a very aesthetically pleasing solution, and I need to figure out something better... it shouldn't look too makeshift.
Translated on 03-09-2026, 5:29.
No new posts Document about lack of power in A4, 2.5 TDI Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Performance issues, black smoke Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku V6 TDI AKE/AYM - Jerking and Lack of Power Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Power shortage ASZ 96kw Upload
No new posts Power loss issue, 96kW PD-TDI (ASZ) #2 Upload
No new posts Performance issues 96kw PD-TDI (ASZ) #3 Upload
No new posts Power loss issue, 96kW PD-TDI (ASZ) #4 Upload
