brezelmann01 Profi-Schrauber
Joined: 09/14/2002 Posts: 714 Karma: +75 / -0 Location: Niedersachsen
22-09-2006, 14:47 Subject: Webasto ThermoTopE Start Noise |
Hi!
"Since I installed my auxiliary heater as a new part 5 years ago, it makes a very loud, deep noise for the first 40-60 seconds when starting. However, it's not a mechanical noise, but rather sounds like a resonance in the exhaust system. Of course, a muffler is installed. The Webasto hotline suggested that changing the CO2 content might eliminate the noise, but unfortunately, it doesn't. Once the flame has ignited, it runs perfectly quietly. But it's only during the ignition phase..."
Has anyone had a similar experience, and perhaps a solution? Otherwise, it's been running perfectly reliably since I bought it, and the error memory is clear.
Dirk. Audi A3 Sportback [8PA], 2.0 TDI CR [CFGB], STH mit FB
Translated on 07-09-2026, 10:52.
Axel M
Joined: 09/22/2006 Posts: 1 Karma: +0 / -0 Location: Krefeld
22-09-2006, 16:55 Subject: Webasto ThermoTopE Start Noise |
That seems to be normal, as mine does the same thing.
It doesn't really bother me.
Axel.
Translated on 07-09-2026, 10:53.
Rolly22 Guest
23-09-2006, 8:17 Subject: Webasto ThermoTopE Start Noise |
It's a resonance noise. As long as the noise doesn't occur during normal operation, you don't need to worry. For the warm-up phase, there was a solution: drilling a 3mm hole in two specific locations in the exhaust pipe to dampen the resonances. However, it didn't always work, and I no longer remember where the holes need to be drilled.
Adjusting the CO2 content can certainly improve the situation, but it can also lead to the 3D printer not functioning correctly when it's warm.
Leave it as it is, even if it doesn't sound very nice.
Rolf.
Translated on 07-09-2026, 10:54.
24-09-2006, 14:28 Subject: Webasto ThermoTopE Start Noise |
Okay, so it seems like it doesn't really help. Too bad. Still, thank you for your answers.
Translated on 07-09-2026, 10:55.
Mephisto Profi-Schrauber
26-09-2006, 10:51 Subject: Webasto ThermoTopE Start Noise |
"My auxiliary heater makes the same noise. It doesn't really bother me. At least that way I know what my auxiliary heater is doing (whether it's starting up or already running)."
A friend of mine has had a similar noise from a parking heater for over 6 years: no problem.
"Micha"
christians Profi-Schrauber
27-09-2006, 11:31 Subject: Webasto ThermoTopE Start Noise |
My auxiliary heater initially made a noise, and then it eventually stopped working because the combustion chamber was clogged with soot. Gruß Christian
Translated on 07-09-2026, 10:56.
wolfi_b Profi-Schrauber
27-09-2006, 13:00 Subject: Webasto ThermoTopE Start Noise |
I wouldn't worry about it. Mine has been making those noises since the very first minute of operation. My father's one does too. 1993 Audi 80 B4 1Z
2004 Seat Leon 1M ASV
