Actually, the GT1749VA shouldn't have a significant turbo lag.
as the VNT15.
Have you checked everything? The hoses, the VTG linkage?
Has the VTG linkage on this loader ever been modified?
Okay, but if you want to exchange it.
So:
The VNT 15 is a turbocharger from the GT17V series, specifically it is a GT1749V.
However, this series is available with different levels of improvements.
Examples: VNT15 (GT1749V)
Performance // VW Part Number // Garrett Part Number
For 110 HP // 028145702 D // 454161-1 or 454161-3)
For 110 HP // 028145702 C // 454158-3
For 110/115 HP // 028145702 H // 454231-1 or 454231/3
For 115 HP // 028145402 R // 454231-2 or 454231-6
These are all turbochargers where the exhaust manifold is not integrated.
You can replace the catalytic converter here without removing the exhaust manifold.
I don't know if that works for golf.
Starting around the year 2000, the chargers for the Golf should have an integrated exhaust manifold.
haben. Diese fangen auch mit einer 038.... Please provide the text you would like me to translate from German to English.
Loaders with a serial number ending in "H" usually have the marking "VNT15" printed on them.
Starting from the R performance level, the chargers are marked with the designation "GT1749V".
See also:
https://community.dieselschrauber.org/en/viewtopic.php?t=8390&highlight=
I'm not aware of a product called "VNT17." This term is usually used as a synonym for...
130 HP TDI engine with turbocharger used.
This one is also from the GT17V series. However, this one already has a higher performance level.
Therefore, GT1749VA. However, within the GT1749VA series, there are also different variations.
Revision levels. For example, VW part number 038145702E or 038145702G, etc.
I hope I was able to help you a little.
