Hello!
Since I found relatively little information when searching or on g**gle,
No information available regarding steering wheel replacement or interchangeability.
between the individual steering wheels of the various models.
I found something, and I'd like to follow up on it.
The leather on the steering wheel of my Ibiza 6k is now starting to...
150,000 km, showing significant wear and reduced grip due to the worn areas.
My goal is to find a steering wheel in 'like new' condition from the Ibiza model series.
_with_ airbags installed.
Ideally, I would prefer one of the current models.
Here begins the problem.
1. I would prefer to do the renovation myself, as I am...
'Spielereien' does not want to sponsor any workshops.
2. Can the steering wheel be removed without special tools?
or install the new steering wheel without using any special measuring instruments.
(without having to steer later in order to drive straight
3. To what extent are the steering wheels interchangeable between different model series?
4 (optional
. It would be great if the old airbag was compatible with the new model.
which is probably not the case, solely based on its shape.
But even with a new steering wheel including a new airbag, it is...
It is questionable whether the compatibility of the control system from the old...
Is the car being recalled due to a new airbag issue?
Please provide as much information as possible. Links to completed renovations.
Post links to sites with similar content!
Thank you in advance.
Best regards.
Peter from Vienna.
