Fixing Errors: Does It Resolve Itself?
worf
Post14-10-2006, 18:45    Subject: Fixing Errors: Does It Resolve Itself? Quote
A few days ago, my Seat Ibiza Cupra TDI displayed the following error message:
After the (cold) start, the engine had very little power. After just a few kilometers, I pulled over to a parking lot, turned off the engine, and restarted it after about a minute. After that, the engine had full power again.
Now I've bought a VAG-COM device and immediately read the error memory. There's something listed there that I'm almost certain is related to this incident.
Code:
1 Fehler gefunden:
18000 -  Signal Höhengeber/Ladedrucksensor: unplausibles Verhältnis
            P1592 - 35-00 -  -
Readiness: 0 0 0 0 0
"It's possible that the control unit just had a temporary glitch, or is something about to fail. The car is still under warranty, so I'll definitely take it to the workshop. According to the error memory, it wasn't just a feeling; there was a real issue."
Greetings from Taunusstein.
Worf.
Translated on 12-10-2026, 14:17.
Audi A4
Karma: +2 / -4   Thank you, like it!
Post14-10-2006, 20:15    Subject: Fixing Errors: Does It Resolve Itself? Quote
The engine went into "emergency mode"; this will be resolved with the next engine start!
Günther
Translated on 12-10-2026, 14:18.
vagtuning
Post15-10-2006, 12:44    Subject: Fixing Errors: Does It Resolve Itself? Quote
Please check the mass wires on the front left longitudinal member, specifically near the strut tower, next to the power steering reservoir, and at the ABS control unit.
If any of the points look like the ones in the attachment, or something similar, then you've found your error.
 Gammel-Masse
 File size:  25.04 KB
 Viewed:  7308 times
Translated on 12-10-2026, 14:19.
No new posts Golf 1J: Auto Volume Changes Automatically Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku A3 8L, Airbag STG error cannot be cleared Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku A3 8L, horn honks by itself Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Siemens PPD: Self-Cleaning or Not? Diesel Engine Technology
No new posts Read TDI error codes yourself... On-Board Diagnostics (OBD)
No new posts Replace ZR on AKN Yourself? Diesel Engine Technology
No new posts Adjusting suspension geometry yourself? Transmission, Chassis, Body & Interior
