Intelligentere AGR-Steuerung? | Posts 32+
Go to page: Previous  1, 2, 3
christians
Post14-10-2006, 0:30    Subject: Quote
Higher combustion chamber temperatures are observed with the EGR system open. Only locally limited peak values decrease (and thus NOx). In this area of Sauerland, I only experienced a maximum of -15°C without any problems. However, for another specific vehicle model (not the ARL), an official regulation imposed a restrictor plate on the EGR system to address issues with engine misfires.
Gruß Christian
Translated on 15-08-2026, 17:19.
gromit
Post18-10-2006, 8:00    Subject: Quote
Take a look at the coolant temperature reading using VAG-COM. On newer VW TDI engines, it fluctuates by approximately +/- 1°C – at least, that's what I see on mine, which suggests pretty good control.
In which measurement block can I find the coolant temperature in VAG-COM?
I haven't really dealt with that much before.
However, there was an official throttle plate for the EGR system, specifically designed to address jerking issues, but it was intended for a different type of PD (presumably not the ARL).
I've also heard about the throttle valve. Does anyone have more detailed information about it?
Best regards.
gromit
Translated on 15-08-2026, 17:20.
No new posts Boost Pressure & P2 Control Explained Diesel Engine Technology
No new posts Function of the VTG control on the VW T5 TDI (AXE) Diesel Engine Technology
No new posts Webasto Heater with CAN Bus Control On-Board Diagnostics (OBD)
No new posts VTG Adjustment: Control or Regulation? Diesel Engine Technology
