Audi 80 B4 Error Codes: Ultra-Detailed Guide
audi80
Post20-10-2006, 11:23    Subject: Audi 80 B4 Error Codes: Ultra-Detailed Guide Quote
Hello everyone!
I recently scanned my car's error memory, and it returned the following results!
Code:
Thursday,24,August,2006,17:55:54
VAG-COM Version: Release 607.2-D
Control Module Part Number: 8A0 907 401 B
  Component and/or Version: 1,9l R4 EDC A23     D09
           Software Coding: 00000
            Work Shop Code: WSC 00000
87 Faults Found:
00000 - End of Output
        00-00 -  -
        00-00 -  -
        00-00 -  -
        00-00 -  -
        00-00 -  -
        00-00 -  -
        00-00 -  -
        00-00 -  -
        125-00 - Unknown Error Elaboration
07816 - Unknown Error Code
        15-00 - Adaptation Limit (Add) Not Reached
25600 - Unknown Error Code
        Unknown - 00-00 -  -
        00-00 -  -
00001 - Brake Control Unit
        112-10 - Unknown Error Elaboration - Intermittent
00240 - ABS Solenoid Valve; Rear Right (N56)
        40-00 - Short to Another Output
12810 - Unknown Error Code
        00-00 -  -
65295 - Development Code 16
        10-00 - Adaptation Limit Not Reached
00256 - A/C Pressure/Temperature Sensor (G395)
        00-00 -  -
00200 - Rear Interior Lamp Button (E327)
        01-00 - Signal Shorted to Plus
01801 - Door Warning Lamp; Drivers Side (W30)
        118-10 - Unknown Error Elaboration - Intermittent
00002 - Transmission Control Unit
        122-10 - Unknown Error Elaboration - Intermittent
01305 - Databus for Infotainment
05377 - Unknown Error Code
        19-00 - Lower Limit
03890 - Unknown Error Code
        00-00 -  -
10416 - Unknown Error Code
65533 - Unknown Error Code
        00-00 -  -
39679 - Unknown Error Code
        Unknown - 117-10 - Unknown Error Elaboration - Intermittent
56829 - Unknown Error Code
        Unknown - 01-00 - Signal Shorted to Plus
        07-00 - Signal too Low
00134 - Outside Door Handle Illumination/mirror Light Rear Right
        00-10 -  - - Intermittent
16327 - Unknown Error Code
        00-00 -  -
00100 - Drivers Interior Locking Button (E308)
        00-00 -  -
        00-00 -  -
        00-00 -  -
        00-00 -  -
        00-00 -  -
        00-00 -  -
        00-00 -  -
        00-00 -  -
        00-00 -  -
        00-00 -  -
        00-00 -  -
        00-00 -  -
        00-00 -  -
        00-00 -  -
        00-00 -  -
        00-00 -  -
        00-00 -  -
        00-00 -  -
        00-00 -  -
        00-00 -  -
        00-00 -  -
        00-00 -  -
        00-00 -  -
        00-00 -  -
        00-00 -  -
        00-00 -  -
        00-00 -  -
        00-00 -  -
        00-00 -  -
        00-00 -  -
        00-00 -  -
        00-00 -  -
        00-00 -  -
        123-10 - Unknown Error Elaboration - Intermittent
38232 - Unknown Error Code
        Unknown - 40-00 - Short to Another Output
36402 - Unknown Error Code
        Unknown - 00-00 -  -
        00-00 -  -
        00-00 -  -
        00-00 -  -
        00-00 -  -
        08-10 - Control Limit Surpassed - Intermittent
39296 - Unknown Error Code
        Unknown - 00-10 -  - - Intermittent
        00-00 -  -
00037 - Footwell/Cabin Temperature Differential Button (E305)
        17-10 - Control Difference - Intermittent
00512 - Camshaft Position (Hall) Sensor not at Reference Mark
        00-00 -  -
36146 - Unknown Error Code
        Unknown - 00-00 -  -
        00-00 -  -
        00-00 -  -
        00-00 -  -
        00-00 -  -
        00-00 -  -
        00-00 -  -
        00-00 -  -
Readiness: N/A
Saturday,02,September,2006,15:14:00
5 Faults Found:
01242 - Output Stages in Control Module
        06-10 - Signal too High - Intermittent
00523 - Intake Air Temp Sensor (G42)
        00-00 -  -
        00-00 -  -
        00-00 -  -
Readiness: N/A
A car scan performed a little later revealed the following:
Code:
Saturday,02,September,2006,14:19:50
Chassis Type: 8C - Audi 80 B4
Scan: 01 02 03 08 15 25 26
Address 01: Engine
   Part No: 8A0 907 401 B
   Component: 1,9l R4 EDC A23     D09
   Coding: 00000
   Shop #: WSC 00000
5 Faults Found:
            00-00 -  -
            00-00 -  -
            00-00 -  -
            00-00 -  -
Readiness: N/A
Address 03: ABS Brakes
   Part No: 4A0 907 379 A
   Component: Bremsen-Elektronik
No fault code found.
Address 08: Auto HVAC
   Part No: 4A0 919 579 C
   Component: Stg. Klimak. 4-Zyl. D07
1 Fault Found:
00532 - Supply Voltage B+
End   --------------------------------------------------------------------------------------------------
Adapter: AI USB without CAN (intelligent).
Symptoms:
Power loss (specifically, lack of torque at low speeds).
Maximum speed not reachable.
Fuel consumption: 9 to 10 liters per 100 kilometers, regardless of driving style.
Maybe you have some ideas!
Georg.
Translated on 28-08-2026, 2:54.
Ross-Tech-Support
Post20-10-2006, 11:53    Subject: Audi 80 B4 Error Codes: Ultra-Detailed Guide Quote
I would say this is a communication problem, and we can already see that because an engine control unit (ECU) from this year simply wouldn't have space to store 87 error codes.
What specific interface are you using? Is it the AI MultiScan USB? Is the latest firmware installed on the interface? Auto-Intern hardware requires separate software for firmware updates; this process does not run through the VAG-COM internal routines. It would also be interesting to try reading the data with a HEX interface; I'm going to venture a guess that this issue wouldn't occur with that type of interface. Where do you live? What is your postal code area?
Translated on 28-08-2026, 2:55.
audi80
Post20-10-2006, 13:14    Subject: Audi 80 B4 Error Codes: Ultra-Detailed Guide Quote
I live in Austria! (Specifically, in Carinthia / East Tyrol / Salzburg)!
Incidentally, this alleged communication error only occurred once.
Adapter: AI MultiScan USB (VAGCOM + dongle function) with the latest firmware.
By the way, I once had a problem with communication where the ÖAMTC (Austrian Automobile Touring and Automobile Club) tried to access the engine control unit (ECU) using three different devices (2 Gutmann, 1 Bosch) – and they were unsuccessful, even though the Bosch device had previously worked!
The errors that were read out using the Bosch and AI adapters are always the same, with only one exception.
Code:
            00-00 -  -
            00-00 -  -
            00-00 -  -
            00-00 -  -
    where the error code 00000 is not documented anywhere and appears repeatedly in the error memory, regardless of the diagnostic tool used.
    But maybe it's not even an error, but rather an EOF marker or something!
    "While error code 01242 is documented, it is not associated with the 'subgroup' 06 - Signal too High, even in the latest original Audi repair manual 'Diesel Direct Injection and Glow Plug System > 02.94', edition 05.97."
I have already performed diagnostics on the actuators, and everything is working except for the exhaust gas recirculation (EGR) system. I'm not sure yet whether it's functioning correctly or not, as the membrane in the valve is damaged, and the EGR system itself is also clogged.
"The turbocharger is producing full boost pressure, but it's building up very late. I've already tested the hoses for leaks."
The LMM (likely referring to a mass airflow sensor) is providing a good signal, as measured by the voltmeter, ranging from 0.xxx to 5.xxx volts.
I hope to be able to check the remaining items (MWB 0, individual measurements, exhaust gas recirculation control) this weekend.
georg
Translated on 28-08-2026, 2:58.
Uwe@Ross-Tech
Post20-10-2006, 15:53    Subject: Audi 80 B4 Error Codes: Ultra-Detailed Guide Quote
The errors listed in that very long list are almost certainly not real. There's some kind of problem, either between the car and the interface, or between the interface and VAG-COM.
You should get in touch with Auto-Intern.
You can also try the standard English version 607.3 from our download page and let us know if you experience the same problem.
http://www.ross-tech.com/vag-com/download/current.html
-Uwe-
Translated on 28-08-2026, 3:01.
No new posts Audi APS Coding: How To & Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Brake fluid change Audi A4 8K Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts _DEFINE0_ Ladelufttemperatur _DEFINE1_ am Audi A3 Technical Articles
No new posts Audi 80 RS2 Steering Wheel Controls: Same as Audi A4 B5? Transmission, Chassis, Body & Interior
No new posts LOG Audi 2.5 AKE Upload
No new posts Audi A6 3.0 TDI ASB: Specs & Info Diesel Engine Technology
No new posts Audi a4 AFN MWB 08 and 11 Upload
