Codici errore Audi 80 B4: guida completa
audi80
Messaggio20-10-2006, 11:23    Oggetto: Codici errore Audi 80 B4: guida completa Cita
Ciao a tutti!
Ho controllato la memoria degli errori e ho ottenuto i seguenti risultati!
Codice:
Thursday,24,August,2006,17:55:54
VAG-COM Version: Release 607.2-D
Control Module Part Number: 8A0 907 401 B
  Component and/or Version: 1,9l R4 EDC A23     D09
           Software Coding: 00000
            Work Shop Code: WSC 00000
87 Faults Found:
00000 - End of Output
        00-00 -  -
        00-00 -  -
        00-00 -  -
        00-00 -  -
        00-00 -  -
        00-00 -  -
        00-00 -  -
        00-00 -  -
        125-00 - Unknown Error Elaboration
07816 - Unknown Error Code
        15-00 - Adaptation Limit (Add) Not Reached
25600 - Unknown Error Code
        Unknown - 00-00 -  -
        00-00 -  -
00001 - Brake Control Unit
        112-10 - Unknown Error Elaboration - Intermittent
00240 - ABS Solenoid Valve; Rear Right (N56)
        40-00 - Short to Another Output
12810 - Unknown Error Code
        00-00 -  -
65295 - Development Code 16
        10-00 - Adaptation Limit Not Reached
00256 - A/C Pressure/Temperature Sensor (G395)
        00-00 -  -
00200 - Rear Interior Lamp Button (E327)
        01-00 - Signal Shorted to Plus
01801 - Door Warning Lamp; Drivers Side (W30)
        118-10 - Unknown Error Elaboration - Intermittent
00002 - Transmission Control Unit
        122-10 - Unknown Error Elaboration - Intermittent
01305 - Databus for Infotainment
05377 - Unknown Error Code
        19-00 - Lower Limit
03890 - Unknown Error Code
        00-00 -  -
10416 - Unknown Error Code
65533 - Unknown Error Code
        00-00 -  -
39679 - Unknown Error Code
        Unknown - 117-10 - Unknown Error Elaboration - Intermittent
56829 - Unknown Error Code
        Unknown - 01-00 - Signal Shorted to Plus
        07-00 - Signal too Low
00134 - Outside Door Handle Illumination/mirror Light Rear Right
        00-10 -  - - Intermittent
16327 - Unknown Error Code
        00-00 -  -
00100 - Drivers Interior Locking Button (E308)
        00-00 -  -
        00-00 -  -
        00-00 -  -
        00-00 -  -
        00-00 -  -
        00-00 -  -
        00-00 -  -
        00-00 -  -
        00-00 -  -
        00-00 -  -
        00-00 -  -
        00-00 -  -
        00-00 -  -
        00-00 -  -
        00-00 -  -
        00-00 -  -
        00-00 -  -
        00-00 -  -
        00-00 -  -
        00-00 -  -
        00-00 -  -
        00-00 -  -
        00-00 -  -
        00-00 -  -
        00-00 -  -
        00-00 -  -
        00-00 -  -
        00-00 -  -
        00-00 -  -
        00-00 -  -
        00-00 -  -
        00-00 -  -
        00-00 -  -
        123-10 - Unknown Error Elaboration - Intermittent
38232 - Unknown Error Code
        Unknown - 40-00 - Short to Another Output
36402 - Unknown Error Code
        Unknown - 00-00 -  -
        00-00 -  -
        00-00 -  -
        00-00 -  -
        00-00 -  -
        08-10 - Control Limit Surpassed - Intermittent
39296 - Unknown Error Code
        Unknown - 00-10 -  - - Intermittent
        00-00 -  -
00037 - Footwell/Cabin Temperature Differential Button (E305)
        17-10 - Control Difference - Intermittent
00512 - Camshaft Position (Hall) Sensor not at Reference Mark
        00-00 -  -
36146 - Unknown Error Code
        Unknown - 00-00 -  -
        00-00 -  -
        00-00 -  -
        00-00 -  -
        00-00 -  -
        00-00 -  -
        00-00 -  -
        00-00 -  -
Readiness: N/A
Saturday,02,September,2006,15:14:00
5 Faults Found:
01242 - Output Stages in Control Module
        06-10 - Signal too High - Intermittent
00523 - Intake Air Temp Sensor (G42)
        00-00 -  -
        00-00 -  -
        00-00 -  -
Readiness: N/A
Una scansione dell'auto effettuata poco dopo ha rilevato quanto segue:
Codice:
Saturday,02,September,2006,14:19:50
Chassis Type: 8C - Audi 80 B4
Scan: 01 02 03 08 15 25 26
Address 01: Engine
   Part No: 8A0 907 401 B
   Component: 1,9l R4 EDC A23     D09
   Coding: 00000
   Shop #: WSC 00000
5 Faults Found:
            00-00 -  -
            00-00 -  -
            00-00 -  -
            00-00 -  -
Readiness: N/A
Address 03: ABS Brakes
   Part No: 4A0 907 379 A
   Component: Bremsen-Elektronik
No fault code found.
Address 08: Auto HVAC
   Part No: 4A0 919 579 C
   Component: Stg. Klimak. 4-Zyl. D07
1 Fault Found:
00532 - Supply Voltage B+
End   --------------------------------------------------------------------------------------------------
Adattatore: AI USB senza CAN (intelligente).
Sintomi:
Perdita di potenza (in particolare, mancanza di coppia ai bassi regimi).
Velocità massima non raggiungibile.
Consumo: da 9 a 10 litri per 100 km, indipendentemente dallo stile di guida.
Forse avete delle idee!
Georg.
Tradotto il 28-08-2026, 2:55.
Ross-Tech-Support
Messaggio20-10-2006, 11:53    Oggetto: Codici errore Audi 80 B4: guida completa Cita
Direi che questo è un problema di comunicazione, e lo si capisce già dal fatto che una centralina motore di questa produzione non potrebbe avere spazio per 87 errori.
Quale interfaccia stai utilizzando esattamente? È un AI MultiScan USB? È installato un firmware aggiornato sull'interfaccia? L'hardware Auto-Intern richiede un software separato per l'aggiornamento del firmware, che non viene eseguito tramite le routine interne di VAG-COM. Inoltre, sarebbe interessante provare a leggere i dati con un'interfaccia HEX; mi permetto di ipotizzare che con quest'ultima non si verificherebbe questo problema. Dove vivi? Qual è la tua zona di CAP?
Tradotto il 28-08-2026, 2:56.
audi80
Messaggio20-10-2006, 13:14    Oggetto: Codici errore Audi 80 B4: guida completa Cita
Vivo in Austria! (A seconda dei casi, in Carinzia / nell'Austria Orientale / a Salisburgo)!
L'apparente errore di comunicazione si è verificato, tra l'altro, solo una volta.
Adattatore: AI MultiScan USB (compatibile con VAGCOM e con funzione dongle), con firmware aggiornato.
Ho avuto un problema di comunicazione in passato, quando l'Öamtc ha tentato di accedere alla centralina con tre dispositivi diversi (2 Gutmann e 1 Bosch), senza successo, anche se con il dispositivo Bosch era già funzionato in precedenza!
Gli errori che sono stati rilevati tramite l'adattatore Bosch e l'adattatore AI sono sempre gli stessi, ad eccezione di un'unica volta.
Codice:
            00-00 -  -
            00-00 -  -
            00-00 -  -
            00-00 -  -
    dove l'errore 00000 non è documentato da nessuna parte e compare sempre più frequentemente nella memoria degli errori, indipendentemente dal dispositivo di diagnostica utilizzato.
    Ma forse non si tratta nemmeno di un errore, ma di un marcatore EOF o qualcosa del genere!
    L'errore 01242 è documentato, ma non è associato alla "sottocategoria" 06 - Segnale troppo alti, nemmeno nell'ultima versione della guida tecnica originale Audi "Sistema di iniezione diretta diesel e preriscaldamento > 02.94", edizione 05.97.
Ho già eseguito la diagnosi degli attuatori, e tutto funziona correttamente tranne il sistema di ricircolo dei gas di scarico, di cui non sono ancora sicuro del funzionamento. La membrana nella valvola è danneggiata e, inoltre, il sistema di ricircolo dei gas di scarico è ostruito.
La pressione di carica è presente, ma si sviluppa molto tardi; ho già verificato che i tubi non presentino perdite.
LMM fornisce un segnale, misurato con il voltmetro, che varia da 0,xxx a 5,xxx volt.
Spero di riuscire a controllare le restanti cose (MWB 0, valori di misurazione singoli, controllo della valvola EGR) nel fine settimana.
georg.
Tradotto il 28-08-2026, 3:00.
Uwe@Ross-Tech
Messaggio20-10-2006, 15:53    Oggetto: Codici errore Audi 80 B4: guida completa Cita
Gli errori elencati in quella lunga lista sono quasi certamente non reali. C'è qualche problema, o tra l'auto e l'interfaccia, o tra l'interfaccia e il VAG-COM.
Dovresti metterti in contatto con Auto-Intern.
Potresti provare anche la versione inglese 607.3 standard dalla nostra pagina di download e farci sapere se riscontri lo stesso problema.
http://www.ross-tech.com/vag-com/download/current.html
-Uwe-
Tradotto il 28-08-2026, 3:01.
Nessun nuovo messaggio Codifica APS Audi: Guida e Soluzioni Errori e Documentazione (Audi, VW, Seat/Cupra, Skoda)
Nessun nuovo messaggio Sostituzione liquido freni Audi A4 8K Errori e Documentazione (Audi, VW, Seat/Cupra, Skoda)
Nessun nuovo messaggio Temperatura dell'aria di carico per l'Audi A3 Articoli Tecnici
Nessun nuovo messaggio Comandi volante Audi 80 RS2: compatibili con A4 B5? Trasmissione, Telaio, Carrozzeria e Interni
Nessun nuovo messaggio LOG Audi 2.5 AKE Upload
Nessun nuovo messaggio Audi A6 3.0 TDI ASB: Ricambi e Informazioni Tecnologia Motori Diesel
Nessun nuovo messaggio Audi A4 AFN MWB 08 e 11 Upload
