Golf 3 Door Speakers: Upgrade & Installation
Post21-10-2006, 16:50    Subject: Golf 3 Door Speakers: Upgrade & Installation Quote
HI.
What is located behind the speakers in the front doors (G3 doors) if they are installed from the factory?
I only had the factory-installed door panels, and I installed matching ones in the doors. After about 5 VWs with leaky window films, I definitely started leaving the film fins attached behind the subwoofers.
Following: Zero Bass.
In the Leon/Golf 4, the subwoofers resonate nicely into the door cavity (i.e., the interior space) and are even acoustically sealed against the door panels.
Are the G3 speakers' diaphragms factory-cut, or how can I achieve resonance and, consequently, improve the sound volume?
PS: I also want to be able to listen quietly sometimes, but still hear well – I have a 30-inch subwoofer in the trunk for when I want to blast the bass.
Translated on 02-11-2026, 10:31.
golf3schrauber
Post22-10-2006, 13:06    Subject: Golf 3 Door Speakers: Upgrade & Installation Quote
In my Golf, the foam seal behind the speaker openings creates a kind of pocket. The plastic film is pushed inwards in those areas, resulting in a slightly larger space.
I cut the film as described below. I haven't experienced any water ingress issues so far.
Gruss Oliver.
Polo 6N,AEE,55KW, von 96
Audi A4 B7, BPP von 2006
Translated on 02-11-2026, 10:33.
No new posts Golf 4 Fault Code Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf IV 1.9 TDI AXR - Stutters under load Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 5 1.4 BUD Misfire 2. Cylinder Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 3 Speedometer with Golf 4 6-speed? No signal. Diesel Engine Technology
No new posts Golf 2 GTD/16V: Brake Caliper & Wheel Bearing Mount Transmission, Chassis, Body & Interior
This topic is locked, you cannot edit or reply. Golf 3 TDI: Install 6-Speed Golf 4 Transmission Diesel Engine Technology
No new posts Golf 3 Instrument Cluster in Golf 2 Dashboard Transmission, Chassis, Body & Interior
