Engine Flush: How to Properly Water Your Engine
Diesel-Dirk
Post10-05-2002, 19:24    Subject: Engine Flush: How to Properly Water Your Engine Quote
Unfortunately, I was driving a bit too fast and ended up going through a huge puddle. The engine stalled and that was it.
After a short pause, the starter motor stopped working. Suspected cause: short circuit -> dead battery. However, that wasn't the problem. Removed the air filter -> it was soaking wet!
Luckily, a friendly hardware store owner next door lent me some tools from his shelves.
'I removed the spark plugs, and the engine immediately started turning again and spitting out water. Then I put the spark plugs back in and ran the engine as a naturally aspirated (non-turbo) engine. I quickly drained a cup of water from the intercooler and then reassembled everything. After a short period of sputtering and water coming out of the exhaust, the car is running again. So far, I haven't noticed any loss of power.'
What long-term consequences can I expect after such an action?
Has anyone else experienced something similar?
Translated on 15-10-2026, 5:43.
Michael II
Post10-05-2002, 21:39    Subject: Engine Flush: How to Properly Water Your Engine Quote
Just a quick question, by the way:
How deep was the puddle? (Was it a normal puddle or a small lake icon_cool.gif)
Tschüss
Michael II
Translated on 15-10-2026, 5:45.
Diesel-Dirk
Post11-05-2002, 16:50    Subject: Engine Flush: How to Properly Water Your Engine Quote
It was quite a deep puddle. The wave in front of the car washed leaves between the hood and the grill.
Michael II
Post12-05-2002, 8:46    Subject: Engine Flush: How to Properly Water Your Engine Quote
I would definitely recommend an oil change. Also, check the other containers for any signs of water (coolant, power steering fluid, etc.).
Tschüss
Michael II
Diesel-Dirk
Post12-05-2002, 11:28    Subject: Engine Flush: How to Properly Water Your Engine Quote
I've also been thinking about getting an oil change.
Water traces in the coolant?
No water should have gotten into the power steering fluid.
I'm more concerned that my turbo might be upset about the whole situation. I'm not sure if it got a large stream of fluid or just a few drops. There was so much fluid inside the engine that it wouldn't even turn over with the starter.
Translated on 15-10-2026, 5:46.
Post12-05-2002, 13:48    Subject: Water Damage? Get Help Now! Quote
Diesel-Dirk wrote:
I'm more concerned that my turbo might be upset about the incident. I don't know if it received a large stream or just droplets. There was so much inside the engine that it wouldn't even turn over with the starter.
Hi.
The water has long since drained out of the charger. If it's working normally now, I don't think there should be any late-stage damage.
If I were in your position, my biggest concern would be the engine: if the piston movement is stopped by a water cushion, it often leads to "water hammer." The compressing piston hits the "water wall," and the sudden deceleration of all moving parts in the engine can cause connecting rods to bend, etc.
It typically occurs as a result of defective cylinder head gaskets.
Translated on 15-10-2026, 5:48.
No new posts AJM Engine: Rattling, Power Loss, Black Smoke Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AFB Engine Overview Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 2.0 TDI Engine Coolant Leak Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Smoking engine after engine/turbo replacement Diesel Engine Technology
No new posts TDI Engine with Gas Transmission: Possible? Diesel Engine Technology
No new posts 1Z Motor Audi 80 B4: Make the engine more fuel-efficient Diesel Engine Technology
No new posts AEL engine in T4 - Ex-ACV Diesel Engine Technology
