steilheckOl
22-10-2006, 19:24 Subject: ECU Same? Check Compatibility Now! |
Hello.
Are the control units with the part number 1Z always the same?
"Will an engine control unit (ECU) from a Volkswagen Golf 3 also fit into an Audi 80 B4 if they have the same engine code (MKB)?"
Best regards.
[Edit Admin ??????? shrunk]
Translated on 21-10-2026, 8:17.
Rudi Guest
22-10-2006, 19:30 Subject: ECU Same? Check Compatibility Now! |
No!
Even Golf 3 models are not necessarily compatible.
Rudi
steilheckOl
22-10-2006, 21:53 Subject: ECU Same? Check Compatibility Now! |
Hello.
Okay, that's annoying.
Thank you.
"MFG" is an abbreviation for "mit freundlichen Grüßen," which means "best regards" or "sincerely." It is commonly used in German-language emails and letters.
Translated on 21-10-2026, 8:18.
