VP44 Bleeding: How to Bleed Your Injection Pump
Gottlike
Post21-10-2006, 20:01    Subject: VP44 Bleeding: How to Bleed Your Injection Pump Quote
Hello.
Now, I also had a significant problem getting the V6 TDI to start after replacing the fuel filter once.
Does anyone have a well-functioning guide on how to perform the filter change in the best possible way?
Here, I have only found one thing so far, but I can't really make much sense of it: /viewtopic.php?t=7228&highlight=vp44+entl%FCften.
If there's already something written about it, please provide the link.
Translated on 17-08-2026, 11:59.
christians
Post21-10-2006, 20:46    Subject: VP44 Bleeding: How to Bleed Your Injection Pump Quote
Okay, I'm ready. Please provide the German text you want me to translate into English. I will only provide the translation.
Gruß Christian
Translated on 17-08-2026, 12:00.
Gottlike
Post24-10-2006, 19:48    Subject: VP44 Bleeding: How to Bleed Your Injection Pump Quote
You probably mean this passage...
I bought a special oil pump for this purpose. It's connected to the ESP instead of the leak oil line, and then you clamp off the return flow before the filter. You pump until no more air comes out, then crank the engine while the pump is running. If the tank is completely full, you don't have to worry about the overflow reservoir, which might otherwise be emptied; just connect the fuel pump directly via a fuse or occasionally turn the ignition on and off.
I don't quite understand that.
What exactly does it mean:
- Disconnect the return line before the filter (what does that look like in practice?).
- then operate with the pump running?
But I can see that there probably isn't a quick and easy way to do it.
Translated on 17-08-2026, 12:02.
christians
Post24-10-2006, 21:14    Subject: VP44 Bleeding: How to Bleed Your Injection Pump Quote
Yes.
- Clamp the return line before the filter (what does that look like in practice?). Secure it with a special clamp or a C-clamp.
- Then, with the pump running, start "orgling"? Initially, just run the pump for a while without any or with only a small amount of air coming out, and then start "orgling" while the pump is still running. VAG has a hand vacuum pump with a collection container attached to it for this purpose.
No. It's like in "Das Boot," when the engine starts up again after the bombing...
Gruß Christian
Translated on 17-08-2026, 12:04.
No new posts TDI Fuel Pump Priming: How to Bleed It Troubleshooting & Guides
No new posts Keyless Entry Installation Guide by IN.PRO Troubleshooting & Guides
No new posts Starting problems and glow plug system issues in TDI engi... Technical Articles
No new posts Coolant pump / Filling and bleeding Diesel Engine Technology
No new posts Bleed brakes with ABS, Bosch version 5.3 Diesel Engine Technology
No new posts Brake Stuck After Bleeding? 3BG PD TDI Transmission, Chassis, Body & Interior
No new posts WordPress Plugins: A Beginner's Guide On-Board Diagnostics (OBD)
