25-10-2006, 10:33 Subject: Intake Manifold: Vacuum Connectors, AGR, and Corners |
HI.
For those who are interested:
The AGR valves with hose clamp connections are NOT compatible with the AGR inlets that have clip connections.
The Klips colleagues are taller.
That makes my plan to add a shut-off valve to the 1Z even more complicated  .
I need some Golf AGR clips (specifically EURO3 compliant) right now. (I have Golf and Passat clips already.)
QUESTION:
Is a pressure pipe with the layout shown in the sketch below problematic?
Then I would build an adapter to connect the Passat fitting to the Golf AGR valve.
| Description: |
| File size: |
1.97 KB |
| Viewed: |
1388 times |
| Description: |
| File size: |
25.45 KB |
| Viewed: |
9075 times |
Translated on 24-10-2026, 14:20.
Profile PM Garage |
Devilseye503 Guest
25-10-2006, 15:08 Subject: Intake Manifold: Vacuum Connectors, AGR, and Corners |
Yes, it's unfavorable. So, referring to the first image, vortices form in the corners, which causes a loss of flow and, consequently, a pressure loss.
Just how bad is it, really? If that were a perfect 1:1 representation, that would be quite something, but I doubt it's actually that accurate, right?
Translated on 24-10-2026, 14:22.
25-10-2006, 15:29 Subject: Intake Manifold: Vacuum Connectors, AGR, and Corners |
No.
It looks like this in reality: (the paper is the suction pipe, and underneath it is the EGR valve).
| Description: |
| File size: |
35.5 KB |
| Viewed: |
1335 times |
Profile PM Garage |
Devilseye503 Guest
25-10-2006, 16:46 Subject: Intake Manifold: Vacuum Connectors, AGR, and Corners |
It's hard to say exactly how it behaves, but I'd guess the diameter is about 8 mm larger, right?
http://iva.uni-ulm.de/PHYSIK/VORLESUNG/fluidemedien/node39.html
http://de.wikipedia.org/wiki/Turbulente_Str%C3%B6mung
You could read a bit about it  , but figuring out how it behaves... not just the pressure loss - which would be simple enough - but also how the turbulence in the combustion chamber continues, and then dealing with constantly fluctuating flow velocities - that's something I'm unsure about  .
Translated on 24-10-2026, 14:23.
30-10-2006, 11:26 Subject: Intake Manifold: Vacuum Connectors, AGR, and Corners |
Okay,
Current status and ongoing project: Building an adapter plate to connect AGR, AHF, and ASV components to the AGR unit on a Passat vehicle.
Translated on 24-10-2026, 14:24.
Profile PM Garage |
