Automatic transmission memory error
Kashi
Post07-11-2006, 22:55    Subject: Automatic transmission memory error Quote
I have a V6 TDI engine with code KB BAU and an EYJ Tiptronic transmission installed in my VW Bus T3. The following error is displayed in the transmission's fault memory:
18265 Last signal error message from the engine control unit: P1857 -35-00--.
The engine isn't responding to the accelerator, and the transmission is shifting roughly. I haven't installed the ABS control unit because it doesn't fit.
What could be the reason for that? Thank you in advance.
Best regards, Kashi.
VW-Bus T3 mit V6 TDI Tiptronic
VW Bus syncro 16" mit AFN
T5 BiTDI DSG
Translated on 14-07-2026, 9:27.
Herr Antje
Post08-11-2006, 7:03    Subject: Automatic transmission memory error Quote
"I had similar issues (also known as a load signal problem) with my ESP or ABS system (I'm not sure which one), and it turned out to be the connector for the mass airflow sensor (MAF) that wasn't properly connected. Take a look at the MAF sensor readings."
Aktuell:
- G3 VR6 '93 128 kW, MKB: AAA
Translated on 14-07-2026, 9:28.
No new posts Caddy Bj 07 BLS AGR Error Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Touran Light Fault (FLA, MDF) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Faulty solenoid valve for turbocharger pressure regulation Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts G28 Error: Find the Mistake! Diesel Engine Technology
No new posts ABS error On-Board Diagnostics (OBD)
No new posts AGR errors On-Board Diagnostics (OBD)
No new posts WFS Errors: Troubleshooting and Solutions Diesel Engine Technology
