Golf TDI: Original EEPROM Chips
rudi72
Post23-12-2002, 15:35    Subject: Golf TDI: Original EEPROM Chips Quote
Hello everyone.
Unfortunately, while playing around with things that shouldn't be touched (like soldering on the engine control unit), I accidentally destroyed the data on my original EEPROMs. Does anyone happen to have the factory-loaded files for the two EEPROMs and could they send them to me?
Engine Control Unit (ECU) Number: VW 028 906 021 C.
Bosch part number 0 281 001 170/171.
Numbers on the EEPROMs: 2 287 358 696 or 7.
0 281 001 171
As described above, it's a 1994 Golf TDI with engine code 1Z.
It's really a pain when the car stops working; it's definitely a lesson learned; stay away from things you're not 100% sure about.
I would appreciate any help you can offer - after all, it's Christmas tomorrow.
Email address: [email protected]
Happy holidays, Rudi!
Translated on 07-09-2026, 6:03.
plexi32
Post23-12-2002, 17:31    Subject: Golf TDI: Original EEPROM Chips Quote
Hmm, I doubt anyone here can help you. Maybe try contacting a tuner like ***; they might have the original data for the EEPROMs. With a bit of luck, they might be able to send you the correct one.
Good luck.
plexi32
Translated on 07-09-2026, 6:05.
Arno
Post23-12-2002, 20:26    Subject: Golf TDI: Original EEPROM Chips Quote
Hi.
If the EPROMs have a small, round window (which should be covered), they are not easily erased (only with UV light). However, it's possible that you didn't follow ESD protection measures (Electrostatic Discharge protection regulations) when soldering on the EDC (Electronic Data Carrier). This could mean that you exposed your EDC board or some of its components to overvoltage damage (only work on it while properly grounded). It doesn't necessarily have to happen, but it's a possibility!
Perhaps this will be helpful to you.
Arnold.
Translated on 07-09-2026, 6:06.
tim27
Post24-12-2002, 16:45    Subject: TDI Chip Data: Tuning & Performance Quote
hello,
If it helps, here are the specifications for a Passat from 1996, model 1Z, engine 35i. But if you're already planning to get new chips, I have some from ******** or Ah Tuning, although I'm not entirely sure which ones.
Translated on 07-09-2026, 6:07.
Corrado_TDI
Post24-12-2002, 17:57    Subject: Golf TDI: Original EEPROM Chips Quote
HiHi
I have the originals!
Translated on 07-09-2026, 6:08.
No new posts Golf 4 Fault Code Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 1J Doku: Clicking Noises (Up to KW 16/98) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf IV 1.9 TDI AXR - Stutters under load Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Original vs. Aftermarket Parts: Which is Best? Transmission, Chassis, Body & Interior
No new posts VW Sport Suspension: Upgrade & Lowering Transmission, Chassis, Body & Interior
No new posts Log 3, 8, 11 Audi A6 2.5 TDI BDG, Manual Transmission (Or... Upload
No new posts Climatronic Values: Original Data & Readings Diesel Engine Technology
