Supplemental heater using incandescent candle filaments
chli1976
Karma: +185 / -0   Thank you, like it!
Post26-12-2006, 18:57    Subject: Supplemental heater using incandescent candle filaments Quote
Hello
I have a Golf IV AJM model, manufactured in 2001, with 3 glow plugs located in the water flange.
As far as I know, the heaters should be switched on via relays when the inlet temperature is below 5°C and the coolant temperature is less than 50°C.
Just checked with an outside temperature of 0°C and a cold engine to see if there is actually power reaching the light bulbs (using a test lamp). The lamp is not lighting up.
I have already tried the following:
Intake air temperature read out with VAG-COM in the cold state, the values in measurement block 7 are quite consistent. Adjustment diagnosis performed and lamp connected to the terminals --> lamp flashes intermittently. Incandescent bulbs with a 40W lamp
verified --> also OK.
Are there any other parameters that the control unit takes into account besides the temperatures and what is in measurement block 16?
I have already read several topics but haven't found anything suitable.
Thank you.
Post26-12-2006, 19:00    Subject: Supplemental heater using incandescent candle filaments Translating...
[Translating...]
Ja,
die Drehzahl bzw. Klemme DF. (== Last der Lichtmaschine)
Wenn der Motor im Leerlauf tuckert, kann die Lima nicht genug Strom liefern, daher werden die Teile dann ausgeschaltet. Sicherlich hast du im LL gemessen ...
Also Frau an das Pedal, min. 1500 U/min drehen lassen (den Motor, nicht die Frau) und dann nochmal messen.
chli1976
Post26-12-2006, 19:35    Subject: Supplemental heater using incandescent candle filaments Translating...
[Translating...]
Danke
Werde ich gleich mal ausprobieren
Wieviel % düren im Messertblock 16 Spalte 1 stehen bei Lastsignal der Lima
chli1976
Post26-12-2006, 19:56    Subject: Supplemental heater using incandescent candle filaments Translating...
[Translating...]
Habes es gerade probiert
Laptop angeschlossen
Messwertblock 16. nach 10 sec. Motorlauf alle Bits auf 0 gesprungen (Spalte 2)
Lastsignal ca 55% (Spalte 1),
Spalte 3 Relaisansteuerung 00
Motordrehzahl auf 2000 1/min angehoben, Tagfahrlicht ausgeschaltet
Spalte 3 Anzeige 01 (Relais für kleine Heizleistung ein --> Lampe leuchtet)
Spalte 1 Lastsignal ca. 30%
No new posts Information about glow plug spark plugs (glow plugs) Technical Articles
No new posts Additional coolant heater for the TDI Technical Articles
No new posts Some information about the longlife service Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Zusatzheizung im T5 On-Board Diagnostics (OBD)
No new posts Steuergerät für Zusatzheizung Diesel Engine Technology
No new posts Additional Heater for Sharan On-Board Diagnostics (OBD)
No new posts Adjusting the auxiliary heater On-Board Diagnostics (OBD)
