ASR-Fehlermeldung beim A4 AFB | Posts 16+
Go to page: Previous  1, 2
mserge
Post29-12-2006, 9:06    Subject: Quote
It could be as simple as a relay or diode being faulty, or just a simple contact being broken. Most of the time, only minor things break, and you end up having to pay a lot for repairs.
This is safety electronics (ABS-ESP), which is precision electronics, and it doesn't break down as quickly as we all think. Most of the time, it's a minor mechanical issue in a connector, solder joint, or relay.
neuer Turbo bei 200.000km
neue ESP bei 216.000km
verkauft mit 225000tkm
Clio 2 RS 170 PS BJ2003
harj
Post29-12-2006, 15:21    Subject: Quote
Apparently, this is a common issue with Bosch ABS systems. The relays were fine, and I've already welded something, so we'll see how often this part fails in the near future. javascript:emoticon('icon_evil.gif')
Evil or Very Mad.
Sepp.
No new posts Timing belt replacement on a 1.9L PD TDI Troubleshooting & Guides
No new posts TDI Synchronization Angle: What is it? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Adaptation channels in TDI engines Troubleshooting & Guides
No new posts VCSCOPE.EXE Error: Troubleshooting Diagram Issues On-Board Diagnostics (OBD)
No new posts VCDS error message on a Seat Ibiza 1.6 TDI CR, year 2010 Upload
No new posts Turbocharger Error: Boost Control Issue On-Board Diagnostics (OBD)
No new posts Alarm System Error: Troubleshooting Guide On-Board Diagnostics (OBD)
