Grone76 Guest
28-08-2002, 21:53 Subject: Alternator Problems? Get Fast Repair! |
I drive a second-generation Golf TD, and I'm having a problem: the charging light never comes on, even when I just turn the ignition on. When I use a different alternator, it works correctly, so the diode isn't faulty.
However, I didn't want to give up the old alternator because it has the W terminal for the tachometer, which the other one doesn't.
Okay, my question is: Is there anything that can be done about this part, or not? I would like to be notified if the LM (likely referring to a light module or similar) stops working.
Thank you in advance for your tips!
Translated on 05-10-2026, 2:06.
29-08-2002, 17:36 Subject: Replace Regulator? Troubleshooting Guide. |
Hi.
Perhaps replacing the regulator would help, especially if those thin wires are connected to it. Gruß Ulf
Translated on 05-10-2026, 2:07.
Profile PM Garage |
olli Profi-Schrauber
Joined: 05/24/2002 Posts: 581 Karma: +46 / -0 Location: Berlin
29-08-2002, 21:51 Subject: Alternator Problems? Get Fast Repair! |
Okay, let's do a test with a voltmeter on the battery. The alternator is "pre-excited" via the charging indicator light or LED. If this pre-excitation is missing (I can't recall the terminal designation at the moment, but you can find it in a wiring diagram you trust), then the charging voltage at idle will not be significantly higher than the battery voltage when the engine is not running. Only when a certain engine speed is reached will you get the full onboard voltage (until the next time the engine is turned off).
I once had a similar LIMA problem, but in that case, the wiring to that terminal was faulty, not the LIMA itself.
I can easily imagine that this could also happen within the LIMA system. So, if replacing the controller doesn't help, then you need to open it up and take a look inside.
Olli.
Translated on 05-10-2026, 2:08.
