VAG-COM: Strange Values on Audi A4 (1995)
prototyp80
Post04-08-2005, 8:37    Subject: VAG-COM: Strange Values on Audi A4 (1995) Quote
I'm having a problem reading and logging data from the mass airflow sensor (MAF) in a 1995 Audi A4 1.8L ADR.
If a measurement value (MWB) is labeled with "speed," for example, it is possible that the value is given in g/s and does not correspond to the actual speed icon_eek.gif icon_question.gif. In another MWB, the mass flow rate (LMM) might be indicated with "ms," etc.
Is VAG-COM too new for this vehicle, or is the vehicle too old for VAG-COM? Or do I have a problem with the software or hardware, or is the issue related to the vehicle's control unit?
Thank you for your help.
Sebastian.
Passat Variant 1.9 TDI (AVF) 2WD Modell 2005
Citroen C3 1.6 16V HDi Bj 2007
Translated on 31-08-2026, 15:57.
Post04-08-2005, 9:17    Subject: VAG-COM: Strange Values on Audi A4 (1995) Quote
Hi Sebastian,
Could you please provide the complete VAG part number of your control unit?
Reason: Using the VAG part number, VAG-COM searches for a suitable label file for your control unit. This file, among other things, defines the names of the fields in the measurement blocks (it is a text file).
If a label file is not found, VAG-COM attempts to guess the type of the values, which can of course lead to errors.
Translated on 31-08-2026, 15:59.
prototyp80
Post04-08-2005, 9:46    Subject: VAG-COM: Strange Values on Audi A4 (1995) Quote
Hi Rainer,
I don't have the number readily available icon_redface.gif; I'll have to check again after work.
Denke mit der Fahrgestellnummer kannst Du nichts Anfangen?! I would have...
Sebastian.
Translated on 31-08-2026, 16:00.
Post04-08-2005, 10:06    Subject: VAG-COM: Strange Values on Audi A4 (1995) Quote
No, the chassis number doesn't help icon_smile.gif. The VAG part number of the respective control unit is displayed directly in the first screen on the left side in VAG-COM when you access the control unit.
Translated on 31-08-2026, 16:01.
prototyp80
Post04-08-2005, 20:35    Subject: VAG-COM: Strange Values on Audi A4 (1995) Quote
Hello Rainer,
Okay, I now have the number of the control unit.
8D0 907 557 CX
Sebastian.
Post04-08-2005, 21:35    Subject: VAG-COM: Strange Values on Audi A4 (1995) Quote
is the content of.
[Edit]
dead link
[Edit]
plausible?
If yes, save the file as 8D0-907-557-CX.lbl in the 'Label' directory.
Translated on 31-08-2026, 16:02.
prototyp80
Post05-08-2005, 6:20    Subject: VAG-COM: Strange Values on Audi A4 (1995) Quote
Hello Rainer,
It's good that we'll have the weekend soon, then I can check that. icon_confused.gif
Sebastian.
Translated on 31-08-2026, 16:03.
Post05-08-2005, 6:50    Subject: VAG-COM: Strange Values on Audi A4 (1995) Quote
You can also try searching on Google (e.g., next week).
Ross-Tech-Support
Post05-08-2005, 11:25    Subject: VAG-COM: Strange Values on Audi A4 (1995) Quote
Rainer K. wrote:
http://www.ross-tech.com/vag-com/download/label-files/8D0-907-557-C.lbl
Rainer K. wrote:
You can also try searching on Google (e.g., next week) for...
Translated on 31-08-2026, 16:04.
Post05-08-2005, 11:46    Subject: VAG-COM: Strange Values on Audi A4 (1995) Quote
Besswerwisser wrote:
Hi Sebastian S.,
You don't need to post anonymously to draw attention to files that were requested and created on August 3, 2005. Especially if you consider time zones...
Okay: Sebastian S. has updated the link at Ross-Tech and added some files.
http://www.ross-tech.com/vag-com/download/label-files/8D0-907-557-ADR.lbl
Either save the file using your VAG part number, or copy the entire directory to your label directory (make sure to back up and empty the directory first).
Since the .zip file is from April, the easiest way is to use 'wget' or a similar tool.
Translated on 31-08-2026, 16:05.
Ross-Tech-Support
Post05-08-2005, 13:12    Subject: VAG-COM: Strange Values on Audi A4 (1995) Quote
http://www.ross-tech.com/vag-com/download/label-files/8D-01.lbl
...then, if appropriate, one should also suggest that he use the corresponding redirect... icon_lol.gif
...then he can save himself the trouble of renaming it... (provided that VAG-COM 405.0 or higher is available). icon_redface.gif
Rainer K. wrote:
You don't have to post anonymously...
I don't think I was wanted in a different way... but we can talk about that privately, or not at all... icon_eek.gif
Translated on 31-08-2026, 16:07.
Post05-08-2005, 13:54    Subject: VAG-COM: Strange Values on Audi A4 (1995) Quote
...then, if appropriate, one should also suggest that he use the corresponding redirect. icon_lol.gif
...then he can save himself the trouble of renaming it... (provided VAG-COM 405.0 or higher is available). icon_redface.gif
Yes, but then he should update everything, so the entire label directory. It's just more work, and eventually, there will be another update from me where I'll repackage the installation.
Translated on 31-08-2026, 16:08.
Ross-Tech-Support
Post05-08-2005, 14:10    Subject: VAG-COM: Strange Values on Audi A4 (1995) Quote
That's right. For simplicity's sake... fresh and new.
http://www.Ross-Tech.com/vag-com/download/label-files/Labels.50805.zip
Translated on 31-08-2026, 16:09.
Post05-08-2005, 14:30    Subject: VAG-COM: Strange Values on Audi A4 (1995) Quote
That's right. Then, for simplicity's sake... fresh and new.
Thank you, that saves time.
prototyp80
Post08-08-2005, 11:28    Subject: VAG-COM: Strange Values on Audi A4 (1995) Quote
I now have the link. Do I need to save the old labels, delete them, and then save the new ones? icon_rolleyes.gif
By the way, I have VAG-COM 504.1, so it shouldn't cause any problems!
Thank you for your efforts icon_razz.gif icon_exclaim.gif.
Sebastian.
Translated on 31-08-2026, 16:10.
Post08-08-2005, 12:18    Subject: VAG-COM: Strange Values on Audi A4 (1995) Quote
There are several ways to handle this, but the simplest would probably be to rename the existing label directory and use the zip file as the new 'label' directory.
Translated on 31-08-2026, 16:11.
No new posts Document A4 8D, up to 9/1995, horn function faulty Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Funny Brake: Troubleshooting & Repair Guide Transmission, Chassis, Body & Interior
No new posts Turbo Adjustment Rod: Troubleshooting & Repair On-Board Diagnostics (OBD)
No new posts Comic resonance oscillation at idle Diesel Engine Technology
No new posts Strange Noises During Operation and Load Changes Diesel Engine Technology
