Octavia 110PS doesn't start
Rip-J
Post26-08-2005, 17:08    Subject: Octavia 110PS doesn't start Quote
I have the following problem:
My Octavia 110PS TDI sometimes doesn't start or simply cuts out while driving. I have already read out the error codes with the following result:
ECU Part Number: 1J0 907 379 H
Part and/or Version: ABS/EDS 20 IE CAN 0001
Encoding: 13304
Workshop Code: WSC 31480
1 Error codes found:
01314 - Engine Control Unit
49-10 - No communication - Sporadically
What else I noticed was that the error occurred when the temperature was very high. It then usually disappeared in the later evening hours. My suspicion was that it might be due to the resistance of the water pipes, which might increase at higher temperatures.
Does anyone perhaps know the cause of this phenomenon?
Post26-08-2005, 18:38    Subject: Re: Octavia 110PS doesn't start Quote
Have you already checked the article for common mistakes?
Rip-J
Post26-08-2005, 20:08    Subject: Octavia 110PS doesn't start Translating...
[Translating...]Ja da hab ich den Hinweiß auf WFS gefunden. Ist das denn möglich das es im ABS Steuergerät einen Eintrag darüber gibt?
Post26-08-2005, 20:10    Subject: Octavia 110PS doesn't start Translating...
[Translating...]
Falsches Ziel . . . was ist mit "109"?
No new posts Document: Engine won't start, Mj 1999 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
This topic is locked, you cannot edit or reply. Pa 3C BMR Won't Start: Error Code 004160 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Octavia springt schlecht an (MKB: AGR) Diesel Engine Technology
No new posts Octavia Starting Problems: ESP Repair Not the Issue? Diesel Engine Technology
No new posts VCDS does not recognize Skoda Octavia; Gateway not supported On-Board Diagnostics (OBD)
No new posts Heizung macht nicht richtig warm im A4 Bj.1997 110PS TDI Transmission, Chassis, Body & Interior
