Audi A6 C4 Diagnostic Connector
New Topic Reply 🔗 🖨 Dieselschrauber - Index » On-Board Diagnostics (OBD)
x world one
Post11-08-2005, 10:04    Subject: Audi A6 C4 Diagnostic Connector Quote
In the earlier production years of the C4 model, there were no ODB2 connectors installed.
Were ODB2 connectors still installed in later models (1996), or did they also have the old connectors?
Since I plan to view some 96 C4 models in the near future, I just wanted to know if I absolutely need to purchase the relatively expensive adapter.
The gasoline engines should also be diagnosable using VagCom.
Spritmonitor
Post11-08-2005, 10:38    Subject: Re: Audi A6 C4 Diagnostic Connector Quote
x world one wrote:
Since I plan to examine some 96 C4 models in the near future, I just wanted to know if I need to purchase the relatively expensive adapter.
With practically every 4-pole connector combination, you can save on the adapter:
Tap into the veins at the OBD-connector, extend the connector into the socket, and the adapter receives the corresponding plug.
It only gets complicated if you try to use it to take advantage of others' vehicles...
christians
Post11-08-2005, 12:40    Subject: Audi A6 C4 Diagnostic Connector Quote
To inspect cars, i.e., before purchasing, a proper adapter would actually be very useful.
As far as I know, all C4s have a 2+2 connection.
Gruß Christian
Post11-08-2005, 13:04    Subject: Audi A6 C4 Diagnostic Connector Quote
christians wrote:
To inspect cars, i.e., before purchasing, a proper adapter would be very useful.
If the seller manages to get a customer to use VAGCOM at all ("instead of messing with the electronics or reprogramming them with amateur equipment, and then the car won't run . . ."), then of course it's also possible to use 4 loose wires with connector contacts that are inserted into the diagnostic port icon_razz.gif
x world one
Post11-08-2005, 15:38    Subject: Audi A6 C4 Diagnostic Connector Quote
Well, I might have to build one myself.
Thank you for the responses. In my last car purchase, I was also able to work on the TDI icon_smile.gif.
Actually, a test drive should be included, as that's the best way to do it. Unless it's a dealer who offers a potential buyer a 20-minute test drive and then insists on dictating the route...
The question is simply how much diagnostic testing can be done on the C4 at all...
(MKB ACK)
Spritmonitor
olli
Karma: +46 / -0   Thank you, like it!
Post14-08-2005, 20:18    Subject: Audi A6 C4 Diagnostic Connector Quote
These connectors are available for 8 cents at Conrad. And in contrast to the description and a comment here in the forum, there are actually all 4 contacts included, and not just 3.
Greetings from Berlin
Olli
A6 CANA/JME /
Ex-A6 AEL
Post15-08-2005, 21:48    Subject: Audi A6 C4 Diagnostic Connector Quote
Olli
slow down, it seems like someone here has read the topic and immediately went for the soldering iron / EBUCHT waste disposal:
...I don't know anymore if it stopped working immediately, or only after...
for a while.
I have a 2 x 2 adapter and I might have plugged the black plug in once.
attempts to insert into the black box on the vehicle because the
The terminal orientation is not immediately apparent due to poor lighting in the engine compartment.
If the device is inserted incorrectly,
...the problem could be due to this...
Incidentally, this is the owner of a C4 icon_evil.gif.
So, wer also sein Diagnosegerät beschädigen möchte, weil icon_smile_thumb_up.gif die 2V und Masse vertauscht wurden (und zwar mit einem vernünftigen 2x2 Adapter, Kabel oder Stecker, die egal wie passen), hat sozusagen Pech gehabt.
I somehow suspected this with the FGB1 and even prepared for such specialists, in which case the power supply is provided via a diode. However, if someone builds a "killer adapter" and suddenly reverses the power supply of a 200-400€ diagnostic device, this will no longer be covered under "warranty" for me. icon_evil.gif
With a reasonable 2x2 adapter, the connectors will not allow for incorrect insertion! And because of the metal retaining clips, the connectors also don't just fall off like other waste!
And since I'm just venting my frustration right now: What do you think, why are there no China-2x2 adapters or diagnostic connectors available in this shop?
Okay, let's do it. Because the businessman wants to make so much money through his systems?
No, even though the Chinese were sending me emails/FAXs full of nonsense because I had looked at their waste and found it to be genuine waste!If it wasn't manure, it would have been included in the offer by now!
Hello, Rainer
 File size:  1.48 KB
 Viewed:  2849 times
 File size:  48.41 KB
 Viewed:  4637 times
No new posts {SOUND_TYPE}: Rumble {VEHICLE_MODEL}: Audi A3 8P Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Brake fluid change Audi A4 8K Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Zuordnung Audi Typ, MKB, GKB, AKB, MJ Technical Data
No new posts Audi 80 RS2 Steering Wheel Controls: Same as Audi A4 B5? Transmission, Chassis, Body & Interior
No new posts Audi A6 3.0 TDI Engine Code: ASB Diesel Engine Technology
No new posts 2L TDI mit 170 PS im Audi A4 B7 Diesel Engine Technology
No new posts Audi A8 4.0 TDI Diesel Engine Technology
