Error Code Reference: Find & Understand Error Codes
Martin4711
Post19-07-2005, 7:54    Subject: Error Code Reference: Find & Understand Error Codes Quote
Can anyone tell me where I can find a reference guide that explains the "error codes" when reading data via OBD2?
habe bei meinem T4 in der Climatronic den Fehler 01273 sporadisch ......nur was könnte es sein? Relais140?
I would be very grateful for an overview.
Martin.
Translated on 21-10-2026, 10:26.
Karma: +807 / -0   Thank you, like it!
Post19-07-2005, 8:38    Subject: Error Code Reference: Find & Understand Error Codes Quote
Hello Martin,
You should try using the search function, for example, with *1273* icon_smile.gif.
/viewtopic.php?t=2029&highlight=%2A1273%2A
Even if the issue doesn't perfectly match your vehicle, the error code 'Fresh air blower V2 - Control difference' indicates...
A complete list of error codes will not be provided here, as that would be unfair to our customers who have registered VAG-COM, as they already receive all those messages through that system.
Translated on 21-10-2026, 10:27.
Martin4711
Post20-07-2005, 11:12    Subject: Error Code Reference: Find & Understand Error Codes Quote
Hello Rainer,
Thank you for the information. However, I did some more searching online last night and found several websites where all the error codes are clearly explained. It's a nice set of documents, and it will be useful for the future.
My problem seems to be related to the blower, which indicates a potential issue with relays 140. In the worst case, it could be the blower itself... it could also be a broken wire.
Martin.
Translated on 21-10-2026, 10:28.
Martin4711
Post25-08-2005, 15:09    Subject: Error Code Reference: Find & Understand Error Codes Quote
For those who want to know...
http://audi100.selbst-doku.de/Main/VAG-COM-Fehlernummern
Martin.
Translated on 21-10-2026, 10:29.
No new posts T4 2,5 ACV Ignition Lock or MSTG General Tips
No new posts Tuning comparison: Chip vs. Powerbox Technical Articles
No new posts Diesel vs. Gasoline: Cost Comparison Technical Articles
No new posts Boost Gauge: Location & Troubleshooting Diesel Engine Technology
No new posts Specialty Tools: Where to Buy & Find Them Diesel Engine Technology
No new posts Engine Control Unit (ECU): Where to Buy? On-Board Diagnostics (OBD)
No new posts Passat 3B Bumper Protector: Where to Buy? Transmission, Chassis, Body & Interior
