Golf, Bora (from 05.00) (Solution)
Michael II
Post05-09-2002, 17:44    Subject: Golf, Bora (from 05.00) Quote
Golf and Bora, starting at 05:00
Content:
ECU Coding
Adjust service interval data
Service interval indicator reset
Adjust fuel level indicator
Consumer Adaptation Adjustment
Coding the ECU:
Composition:
01 Coding Number for Optional Extras
4 Country Code
0 Coding number for service interval (WIV)
3rd Code for Way Impulse Number (K-Number)
Table:
XX Codezahl for Additional Features*
00 no additional equipment active
01 Brake pad wear indicator active
02 Seatbelt warning active
04 Washing water warning active
16 Navigation
If multiple extras need to be coded, the code numbers of the respective extras must be added together.
X Encoding Code for Country Variant
0 Germany (D)
1 Europe (EU)
2 USA (US)
3 Canada (CDN)
4 Great Britain (GB)
5 Japan (JP)
6 Saudi Arabia (SA)
7 Australia (AUS)
X Encoding Code for Service Interval
0 vehicles with fixed maintenance intervals without sensors for oil level/temperature -G266-; PR-No.: QG0
1 Vehicles with flexible maintenance intervals (WIV) with sensors for oil level/temperature -G266-; PR-Nr.: QG1
2 vehicles with fixed maintenance intervals with sensors for oil level/
-temperature -G266-; PR-No.: QG2
3 Vehicles with no service interval indicator (USA, Canada)
X Encoding Code for Way Impulse Number (K-Number)
1 4345
2 3528
3 4134
4 3648
The code number for the steering impulse number depends on the vehicle's motor/gear combination:
1.4 l / 55 kW with manual transmission 1
1.6 l / 74 kW with manual transmission 3
1.6 l / 77 kW with manual transmission 3
1.9 l / 50 kW- SDI with manual transmission 3
1.9 l / 81 kW- TDI with manual transmission, gearbox code 02M 4
all engines with 6-speed manual transmission (including all-wheel drive), 4
all engines with a 5-speed automatic transmission 4
all remaining engine/transmission combinations 2
Adjust service interval data:
Channel 43
Maximum distance to inspection point.
Step: 1000 km
Channel 44
Upper limit for the time until inspection
Step-by-step, 1 day
Channel 45
Oil quality of the filled engine oil:
Vehicles with fixed maintenance intervals (PR-No.: QG0 and PR-No.: QG2):
Input value 00001
Vehicles with a gasoline engine and flexible maintenance intervals (PR-Nr.: QG1):
Input Value: 00002
Vehicles with a 6-cylinder diesel engine and flexible maintenance intervals (PR-Nr.: QG1):
Input Value: 00003
Vehicles with diesel engines and flexible maintenance intervals (PR-No.: QG1):
Input Value: 00004
Channel 40
distance traveled since the last inspection
Step: 100 km
Channel 41
Time since last inspection
Step-by-step, 1 day
Channel 46
Fuel Total Consumption Amount (only gasoline engine)
Step-by-step, 1 liter
Channel 47
Black smoke (only diesel engine)
Step: 100 km
Channel 48
Oil Consumption (Only Diesel Engine)
Step: 100 km
Function: Adaptation
Channel: 2
Value: 0
Channel: 30
Range: 120 to 136
Customize Usage Display
It is only possible to adjust the power consumption display from 85% to 115%.
The input must be provided in 5-step increments.
Channel: 3
Area: 00085 to 00115
Tschüss
Michael II
Ratings - Golf, Bora (from 05.00)
Average rating: 5.00 - worst rating: 5 - best rating: 5 - number of ratings: 1 - View ratings
No new posts Combination instrument, Golf, Bora, 05.99 to 04.2000 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf, Bora combination instrument panel, 1998 to 04.1999 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Battery drain troubleshooting for Golf IV and Bora Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts MSTG ASV aus Golf/Bora, Octavia, A3 ... kompatibel ?? On-Board Diagnostics (OBD)
No new posts Kombiinstrument - Golf 3 Tdi 1Z Bj. ´96 Transmission, Chassis, Body & Interior
No new posts Golf 4 PD Instrument Cluster Transmission, Chassis, Body & Interior
No new posts Golf 4 Dashboard Burned - Instrument Cluster Electrical Systems, Vehicle Electronics, Multimedia
