joegolf Profi-Schrauber
Joined: 04/28/2003 Posts: 257 Karma: +3 / -0 Location: östlich von Stuttgart
22-06-2005, 16:51 Subject: Vehicle Maintenance: Condition & Status |
You often read about how poorly some cars are maintained.
Today, we had a case like that in our workshop. I'll refrain from making any further comments...
Translated on 21-08-2026, 3:32.
ObenbeiMutti Guest
22-06-2005, 16:53 Subject: Vehicle Maintenance: Condition & Status |
But you don't work at ATU  .
guste100 Profi-Schrauber
Joined: 07/27/2004 Posts: 2406 Karma: +441 / -0 Location: Mitte Schleswig Holsteins 2007 Volkswagen Passat Premium Support
22-06-2005, 16:58 Subject: Vehicle Maintenance: Condition & Status |
Why? Surely you can reduce the braking distance by at least another 3-4 mm  .
*duck and cover*
Translated on 21-08-2026, 3:33.
Profile PM Garage |
Mephisto Profi-Schrauber
22-06-2005, 17:18 Subject: Vehicle Maintenance: Condition & Status |
You just photographed the wrong side...
"Micha"
22-06-2005, 17:47 Subject: Vehicle Maintenance: Condition & Status |
ObenbeiMutti wrote: | But you don't work at ATU  | .
No, I got that from my father's body shop. They were actually there for something else...
With the brake pads, they still wanted to go to Italy...
Translated on 21-08-2026, 3:34.
lappen Guest
22-06-2005, 18:39 Subject: Vehicle Maintenance: Condition & Status |
That would have also been enough to reach Greece and back, and then all the way to the Urals, 'and still have some left.' That's just efficient use of materials!
Translated on 21-08-2026, 3:35.
Bertil Profi-Schrauber
22-06-2005, 21:01 Subject: Vehicle Maintenance: Condition & Status |
Who stole the picture of my brake pads that I just replaced...?
So, the ones I just took out of the saddle looked exactly like that.
lappen Guest
22-06-2005, 21:25 Subject: Vehicle Maintenance: Condition & Status |
Exactly! Because whoever brakes is a coward!!!
But seriously, I've personally experienced worse situations involving iron on iron.
Translated on 21-08-2026, 3:36.
22-06-2005, 22:06 Subject: Vehicle Maintenance: Condition & Status |
lappen wrote: | Exactly! Because anyone who brakes is a coward!!!  |
Exactly... braking requires accelerating again... and that costs huge amounts of valuable diesel...!
Quote: |
But seriously, I've had worse iron on iron before.  |
Umm... Yes!
The brand new Ferodo ID346 brake pads after a rally. They were only 200 km old, and the friction material was already completely worn down to the metal.
However, having to complete three circuits, each with four 90-degree turns (each circuit consisting of 2-3 laps), every 2 kilometers will put a significant strain on the braking system.
The last lap was a real "last one wins" kind of race... Farmer Harms' field was completely unrecognizable.
Translated on 21-08-2026, 3:37.
Forenheini Guest
23-06-2005, 12:39 Subject: Vehicle Maintenance: Condition & Status |
They are still good...  a real cabinet of horrors can be found in this book here:
http://www.kirschbaum.de/shop/artikel.php?id=167
Translated on 21-08-2026, 3:39.
isar12 Blaumann
Joined: 05/03/2005 Posts: 42 Karma: +3 / -0 Location: Ampfing /Oberbayern
28-06-2005, 12:33 Subject: Vehicle Maintenance: Condition & Status |
And the other three pieces? They were definitely even better, right?
Did you give him those [items] as a backup? Please don't tell me you threw them away!
No no guys, you'll never save any money that way...
Wartung statt Schutzbrief!
vagtuning Guest
28-06-2005, 21:00 Subject: Vehicle Maintenance: Condition & Status |
We already had one that came in because of grinding noises  .
The brake piston had seized on the disc because it had likely been used for several hundred kilometers or more in that condition.
And today, we also had something nice happen...
http://img104.echo.cx/img104/3633/img00010bk.jpg
He would have definitely lasted a few more meters  .
I was more than surprised that it was still running!
Translated on 21-08-2026, 3:40.
lappen Guest
28-06-2005, 21:13 Subject: Vehicle Maintenance: Condition & Status |
Ah, the speedy shoelace... Wow, that guy obviously has more luck than brains  .
Translated on 21-08-2026, 3:41.
29-06-2005, 8:53 Subject: Vehicle Maintenance: Condition & Status |
"Hi,"
What's wrong with the timing belt? It still has over 30% of its width remaining! How many kilometers has it been driven? 60,000 km? That means there are still about 30,000 km left! (at least if you're as lucky as the car owner).
But another question: How on earth did this happen? And: Actually, the belt should run in the center, even if it's only as wide as a shoelace!
Did the new belt stay centered on the pulley, or did it slip off within the first few kilometers?
"Micha"
Translated on 21-08-2026, 3:42.
Julian Guest
29-06-2005, 8:54 Subject: Vehicle Maintenance: Condition & Status |
What's wrong with the timing belt? It still has over 30% of its width remaining! How many miles has it been driven for? 60,000 km? That means there are still about 30,000 km left! (at least if you're as lucky as the car owner).
Hm, I see this as a weight-optimized version for Ulf. It saves another 30g...
Translated on 21-08-2026, 3:43.
lappen Guest
29-06-2005, 9:11 Subject: Vehicle Maintenance: Condition & Status |
Hmm, I see this as a weight-optimized version for Ulf. It saves another 30g...
...and delivers a gain of 0.01 seconds in the acceleration range from 2000 to 4000 RPM.
Translated on 21-08-2026, 3:45.
