TDI engine warm-start problem - possibly the starter is to blame...
Draven
Post17-10-2002, 12:30    Subject: TDI engine warm-start problem - possibly the starter is to blame... Quote
I recently talked to a mechanic in my workshop about my warm-starting problems with my AHF 110PS TDI.
I suspect that the fuel pump's starting point may not be properly adjusted, or that there may be something wrong with the starting amount...
The mechanic then said that they had recently experienced the exact same problem on an A3 (I don't remember the exact engine code, but it was also a 110PS TDI). After a long search, they had almost completely disassembled the engine before Bosch gave them the tip to replace the starter motor.
And lo and behold, the warm-starting problem was fixed! The master's statement was that the old machine was simply 'too slow' to reach the correct RPM due to the fuel injection adjustment...
I'd like to hear what the experts here think about this...
Oh, and if something isn't 100% explained, please don't immediately jump to conclusions, I was just trying to convey what I was told by the master...
Michael II
Post17-10-2002, 12:43    Subject: TDI engine warm-start problem - possibly the starter is to blame... Quote
Have you checked the error database?
Tschüss
Michael II
Post17-10-2002, 18:58    Subject: Faulty starter Quote
The issue of a weak starter has also been mentioned here several times, but I don't think it has been thoroughly discussed yet.
My AFN has been starting somewhat hesitantly since new (around 3 engine revolutions), but the colder it is, the better.
Adjusting the starting fuel mixture does not necessarily improve things for me: if it ignites faster, the idle speed increases significantly, and the whole thing feels like it's putting more strain on the engine. icon_sad.gif
@MichaelViewing profile: Michael 2: I couldn't find anything relevant in the error database. icon_question.gif icon_question.gif
No new posts Anlasser macht Geräusche, Golf 4 (und Baumustergleiche) Troubleshooting & Guides
No new posts TDI Synchronization Angle: What is it? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Timing belt replacement on a 1.9L PD TDI Troubleshooting & Guides
No new posts Anlasser ausbauen beim Golf 3 Diesel Engine Technology
No new posts Audi a3 Warmstartproblem Diesel Engine Technology
No new posts Warmstartproblem bei TDI Umbau im VW Bus Diesel Engine Technology
No new posts Audi A3 Engine Code BMN Warm-up Problem Diesel Engine Technology
