Adaptive Channels: Ahu Solutions
Markus Vompy
Post08-10-2005, 16:49    Subject: Adaptive Channels: Ahu Solutions Quote
Hello there.
I'm looking for the original adaptation channels for a VW Golf 3 AHU engine.
Specifically, channels 1, 2, 3, 4, and 5. I would appreciate your answers.
I was particularly interested in channel 4 because of the injection start timing. I'm wondering if the original control unit also has a value of 32768 at an angle of 13.1 degrees.
32768 are original values used by the engine control units during calibration.
Thank you in advance.
Translated on 06-08-2026, 9:35.
Post08-10-2005, 17:08    Subject: Adaptive Channels: Ahu Solutions Quote
I have 5 brand new, still in their original packaging, adjustment channels available for €12.99 each.
Everyone also has a nice "32768" included.
Does that help you?
PS: It might help your readers understand your post better if you stated what you're trying to achieve. Right now, it's a bit confusing. Also, "13.1°" doesn't tell us much: Is it in relation to the crankshaft angle (KW)? Is it before or after Top Dead Center (OT)? At what RPM? What engine temperature? Under what load? Is the engine running or not?
Translated on 06-08-2026, 9:37.
Markus Vompy
Post08-10-2005, 21:51    Subject: Adaptive Channels: Ahu Solutions Quote
"Sorry, 13.1° BTDC is the injection timing before top dead center. I wanted to compare it with a Golf 3 that had an aftermarket engine control unit (cheap tuning) installed."
Translated on 06-08-2026, 9:38.
Post08-10-2005, 22:31    Subject: Adaptive Channels: Ahu Solutions Quote
Hi Markus,
Yes, and when are the 13.1 kW from the operating temperature supposed to be reached?
Take a look at the values you're talking about, and you'll see that the injection start point varies between 0 and 15 degrees before top dead center (BTDC), depending on the operating conditions.
Engine tuning boxes usually do not alter the fuel injection timing.
Translated on 06-08-2026, 9:39.
No new posts Adaptation Channels of Engine Control Unit Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AAT Adaptation Channels: A Guide Diesel Engine Technology
No new posts Adaptation channels for older R5 TDI engines On-Board Diagnostics (OBD)
No new posts Audi 100 2.5 TDI: Adaptation Channels? On-Board Diagnostics (OBD)
