Document A3 8P1, BMJ, GMU - Transmission Noise (Solution)
Michael II
Post24-04-2005, 10:47    Subject: Document A3 8P1, BMJ, GMU - Transmission Noise Quote
Clicking sound after engaging the clutch. Audible during all upward movements, especially during the sequences 1 > 2 > 3 > 4.
The clicking sound is amplified when, during or immediately after the clutch engagement, the accelerator pedal is quickly released from the initial 5-10mm of travel, which corresponds to the power range.
Occasionally, the clicking sound can also be heard when quickly releasing the clutch.
Cause:
Gear noise.
The customer should be informed about the following:
"The engine's immense power output can cause knocking noises in the transmission when driven in a very sporty manner."
A brief pre-synchronization during gear changes, combined with a slightly delayed throttle application, prevents the clicking noises.
"Pre-synchronizing refers to briefly engaging the gear lever (for a duration of less than or equal to 0.5 seconds) while the clutch pedal is depressed, before actually selecting the gear."
Tschüss
Michael II
vagtuning
Post02-11-2005, 22:51    Subject: Document A3 8P1, BMJ, GMU - Transmission Noise Quote
For most 3.2L 8P models, there's also a modified software that's supposed to minimize (though not completely prevent) this issue.
Ratings - Document A3 8P1, BMJ, GMU - Transmission Noise
No new posts Documented noises from the dual-clutch transmission, 6-sp... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ATF oil leak on 74 kW TDI engine Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Coolant Loss, AGP, AGR, AHF, ALH, AQM Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Transmission noise Diesel Engine Technology
No new posts Audi A3 8L: Transmission Noise Diagnosis Diesel Engine Technology
No new posts Interessante Doku zum 1.9 TDI Motor Diesel Engine Technology
No new posts AFN Engine Performance Issues: MJ 1998 Documentation Diesel Engine Technology
