Engine Control Unit VP37 for VW T4 AJT-ACV - Data from VAG-COM
Post13-10-2005, 22:15    Subject: Engine Control Unit VP37 for VW T4 AJT-ACV - Data from VAG-COM Quote
good evening,
After cleaning and partially replacing the fuel system of my 1999 VW T4 TDI 65 kW, I need some engine settings from someone. (Also, if possible, the ACV settings).
The fuel tank was heavily corroded inside. It appears the previous owner never drained the fuel.
I have measured the voltage before the disconnection (0.68V). What value do you have?
measurement block 1, 3rd value
motor off - ignition on - read with vag-com:
giver voltage control? ----------I have 0.68V
engine idling
idle speed??--------------I have 1500 rpm
fuel injection amount??---------------mine is 0.0 0.2 mg-horn
Can someone please email me their or the ideal data?
It would be great if someone could take the time.
I am also happy to help others.
greetings to the admin
thank you, Michael Karrer
stummel78
Post16-10-2005, 8:52    Subject: Engine Control Unit VP37 for VW T4 AJT-ACV - Data from VAG-COM Quote
...although I don't have such a vehicle, but I would bet that the injection amount is not correct...I have a 1Z-TDI and the amount at idle is around 5mg/stroke...if I understand correctly, it shows a too low amount for you, but therefore injects too much...try adjusting it by moving the MSW to around 4.5-5mg/stroke and see what happens
Audi 80 Avant TDI 430.000km
Post16-10-2005, 10:59    Subject: Engine Control Unit VP37 for VW T4 AJT-ACV - Data from VAG-COM Quote
Hello Michael,
I think using a mobile phone number as a nickname is a bit unfortunate, as there are already plenty of people who enjoy using that. At your request, I will change your login, just let me know.
To disable the ESP: The easiest way is to adjust it when the engine is warm and running, without any electrical loads being switched on. Simply move the fuel metering unit so that 4-7 mg/stroke is displayed as the injection volume at idle.
Hello, Rainer
No new posts Quantity setting device and control path generator: Function Technical Articles
No new posts Starting problems and glow plug system issues in TDI engi... Technical Articles
No new posts Disassembling the metering unit of a VP37 Troubleshooting & Guides
No new posts Triangle nut f. VP37 turnout frame Diesel Engine Technology
No new posts Adjustment aid for the quantity setting device on the VP37 Diesel Engine Technology
No new posts VP37 ESP: Cleaned Powder Meter According to Instructions. Diesel Engine Technology
No new posts T4 2.5 TDI: Fuel Injector Calibration Issues Diesel Engine Technology
