tdi-seppl Blaumann
Joined: 02/01/2003 Posts: 44 Karma: +6 / -0 Location: Regensburg
01-04-2003, 17:40 Subject: Alternator Carbon Brush Replacement |
hi,
My Golf TDI, model year 1994, now has 316,000 kilometers on the odometer.
Shouldn't we at least consider using activated carbon?
or how long do they last? or should I replace the entire alternator? probably the armature is worn out too.
Hi TDI-Seppl, Baust Du Turbo an Diesel,läuft Diesel wie Wiesel
Translated on 17-09-2026, 12:36.
Tagessuppe Profi-Schrauber
Joined: 11/13/2002 Posts: 1140 Karma: +36 / -0 Location: Wien 2001 Audi A2  Premium Support
02-04-2003, 8:47 Subject: Alternator Carbon Brush Replacement |
At this mileage, it's definitely a good idea to check the brushes. They don't cost much, but a failure is usually very annoying. I would recommend replacing them proactively. Then you'll be worry-free for the next 300,000 kilometers.
Best regards.
Translated on 17-09-2026, 12:37.
Profile PM Garage |
wollif Guest
02-04-2003, 9:40 Subject: Alternator Carbon Brush Replacement |
Hi tdi-seppl,
Just out of curiosity: Is your clutch still the original one? If not, how long did the first one last? And what about the shock absorbers? I have the same model year with 230,000 km on the odometer.
I'm sorry, I don't understand. Can you please rephrase your request?
Translated on 17-09-2026, 12:38.
joergs Guest
02-04-2003, 10:15 Subject: Alternator Carbon Brush Replacement |
@wollif
'I'm not TDI-Seppl, but the rear shock absorbers on my Passat 35i started leaking around 200,000 kilometers. While the front ones were still in good condition. I think it was still the original set of shock absorbers, but I can't be sure because I bought the car used.'
The clutch is likely still the original one and doesn't seem to have any problems.
Translated on 17-09-2026, 12:39.
haehnlein Schrauber
Joined: 08/22/2002 Posts: 877 Karma: +6 / -0 Location: Griesheim
02-04-2003, 12:34 Subject: Alternator Carbon Brush Replacement |
I'm not exactly a "TDI-Seppl" either, but the shock absorbers on our Audi 80 1Z with 270,000 km still had over 70% functionality during the last ADAC inspection -> good. However, the condition depends on the type of roads driven  .
@ tdi-seppl :
How many times have you replaced the crankshaft bolt on your 1Z engine? ____________
Kein Auto mehr!
Translated on 17-09-2026, 12:40.
wollif Guest
02-04-2003, 12:42 Subject: Alternator Carbon Brush Replacement |
Thank you for the answers!
Translated on 17-09-2026, 12:41.
tdi-seppl Blaumann
02-04-2003, 15:55 Subject: Alternator Carbon Brush Replacement |
I am TDI-Seppl.
Okay, I'll replace the alternator when I get the chance.
The clutch is still the original one.
"However, I replaced the front shock absorbers 50,000 km ago because they were leaking."
Besides wear-and-tear parts like brakes, filters, and the timing belt, I have replaced an injector (the one with the sensor) and the glow plugs.
I still intend to achieve that 500,000.
Translated on 17-09-2026, 12:42.
tdi-seppl Blaumann
02-04-2003, 16:01 Subject: Alternator Carbon Brush Replacement |
Here's TDI-Seppl again.
I have always changed the timing belt, idler pulley, and tensioner pulley myself.
I have never changed the crankshaft bolt.
There's already a screw with a strength class of 12.8 installed.
tdi-seppl Baust Du Turbo an Diesel,läuft Diesel wie Wiesel
Translated on 17-09-2026, 12:43.
02-04-2003, 16:03 Subject: Alternator Carbon Brush Replacement |
tdi-seppl wrote: | Then, I will replace the alternator at some point.
Will you really replace the entire lighting system right away?
Just buy new carbon brushes for a few euros from Bosch and install them.
Best regards.
Translated on 17-09-2026, 12:44.
Profile PM Garage |
