Another urgent question about the span element.
Could it be that you can't reassemble this after removing the locking mechanism and extending the piston rod?
This applies to both the old and the new versions of the Spanelemt. You only have a few seconds to adjust the clearance, after which the expansion element seems to fill with oil and lock.
Is that normal
/Jan
