Automatic ZV Lock: Hands-Free Operation
Post19-10-2005, 8:10    Subject: Automatic ZV Lock: Hands-Free Operation Quote
Problem reported by the user: The ZV (central locking system) locks automatically.
What kind of vehicle do you have? Has this model been appearing recently, or is it a more recent issue? Are there any visible damages to the wiring harness that goes to the door? Are there any error codes stored in the system?
Translated on 18-08-2026, 20:59.
Cheffe
Post24-10-2005, 16:59    Subject: Automatic ZV Lock: Hands-Free Operation Quote
I once had something similar on a VW T4. Every time you closed the door, the door would automatically lock. I replaced the locking unit, and that fixed the problem. Hopefully, this gives you some helpful information.
Translated on 18-08-2026, 21:00.
leo_b
Avatar-leo_b
Post24-10-2005, 17:12    Subject: Feather: Small Size, Big Impact! Quote
hello,
I can only share my experience with a T4.
Inside the door lock, there's a small spring that sometimes breaks.
This spring is used to hold the door pin in either the upper or lower position.
If this is broken, the door latch pin will easily slide downwards when locking, and it may prevent the car from being locked remotely.
Otherwise, I would also say it's a broken cable in the door bellows.
Best regards, Leo.
P.S.: I've also already replaced the springs on both doors. With a little skill, it's not a problem. However, the spring itself needs to be custom-made/bent (not an off-the-shelf part).
Translated on 18-08-2026, 21:01.
No new posts Audi A3 Door Auto Open/Close Problem (8L) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Polo MJ 2002: Automatic Door Lock Problem Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Door lock problem: Clicking sound, won't latch Transmission, Chassis, Body & Interior
No new posts Motor wechselt selbständig touren Diesel Engine Technology
No new posts A6 4B Automatik Probleme, schaltet selbständig oder nicht On-Board Diagnostics (OBD)
