Oil pressure sensor in the Golf!
Animalking
Post04-09-2002, 12:10    Subject: Oil pressure sensor in the Golf! Quote
I installed a VDO oil pressure gauge with display yesterday. Here I have the original oil pressure sensor/warning sensor on the oil filter.
detached. Then I screwed in my new oil pressure sensor from VDO into the threaded hole. This has two connections: one for the analog oil pressure gauge and one for the oil pressure warning indicator.
Now the oil pressure gauge works perfectly, however, the oil pressure gauge beeps and flashes when I start the engine. Now, it might be possible that I need to add a resistor between the oil sensor and the warning light.
Post05-09-2002, 6:55    Subject: Re: Oil Pressure Sensor in Golf! Quote
What is the switching point of your new oil pressure sensor?
Normally, it should be screwed in instead of the sender in the cylinder head (switch point 0.25 bar). The one on the oil filter has a different switch point (I'm not sure anymore, but I think 1 bar). Also, the oil pressure at the oil filter is not very informative because the oil only starts its journey through the engine there. At the end of the oil circuit (at the cylinder head), monitoring oil pressure is much more important!!
Animalking
Post05-09-2002, 11:38    Subject: Oil pressure sensor in the Golf! Quote
but the original oil pressure sensor is also located at the oil filter!!
Post05-09-2002, 17:53    Subject: Oil pressure sensor in the Golf! Quote
Please read my post again very carefully!!!
{TEXT_TO_TRANSLATE}
VAG engines have had two oil pressure sensors since 1983. One at the oil filter flange and one at the cylinder head!!!!
If one turns off before the other, then the Warner will hum (just don't ask which switch was turned off first, I forgot)!
Post07-09-2002, 16:04    Subject: @ animalking Quote
Hi Animalking,
Have you solved your problem? It has become so quiet.
Animalking
Post07-09-2002, 18:37    Subject: Oil pressure sensor in the Golf! Quote
Hey,
Thanks for the information!!!
I'll try to screw the sender into the threaded opening on the cylinder head. Maybe that will help! And make sure to use the original oil filter when replacing it, then it might work!
Animalking
Post09-09-2002, 20:34    Subject: Oil pressure sensor in the Golf! Quote
Unfortunately, the old original oil pressure sensor with the mounting bracket is no longer available. However, it should also be possible with the VDO system. However, no one knows whether the cable for the oil pressure warning indicator requires a resistor! icon_cry.gif
Gremlin
Post09-09-2002, 21:28    Subject: Oil pressure sensor in the Golf! Quote
Okay, here's the translation:
so:
@bertil
My TDI (ALH) only has ONE oil pressure switch (on the oil filter housing).
I only know two switches, which I only used with older motors, probably from around 1990.
@animalking
The TDI oil pressure switch switches ON with oil pressure and OFF without oil pressure!
Traditional, old switches would open when there was pressure and close when there was no pressure.
...also confused me the first time I measured it...
See you, Gremlin
Animalking
Post09-09-2002, 23:57    Subject: Oil pressure sensor in the Golf! Quote
First of all, thank you for the information.
Now I'm just a little bit confused!
The VDO sender has connections for both the oil pressure and the warning indicator (at least that's what the seller said). Now, I simply connected the connection from the warning indicator on the sender to the old cable that was originally connected to the original sender. I didn't quite understand what you meant about the ground icon_question.gif? Do you mean that if I connect the cable from the oil pressure warning light to ground, it won't scream anymore? Despite everything, thank you.
Post10-09-2002, 6:27    Subject: Oil pressure sensor in the Golf! Quote
Gremlin wrote:
@bertil
Hi Gremlin,
My 1Z has two, the ALH of my neighbor has two, and the 110PS TDI (Seat Toledo 2000) from my brother also has two oil pressure sensors (I can remember that quickly). Should there be different versions?
@animalking
The VDO sender has connections for both the oil pressure and the warning indicator (at least, that's what the seller said).
That's also fine...
Now, I simply connected the connection from the warning indicator on the sensor to the old cable that was originally connected to the original sensor. I didn't quite understand what you meant by the "ground"? Please explain in more detail, do you mean that if I disconnect the cable from the oil pressure warning light, it will no longer make a noise?
The switches on the engine are switched via ground (engine block). There are switches that close when there is oil pressure, or switches that open when there is oil pressure. The latter ones you cannot use, then your alarm will sound. That was the statement made by Gremlin.
It's possible the salesperson gave you the wrong switch. That's the only way to do it.
Gremlin
Post10-09-2002, 6:29    Subject: Oil pressure sensor in the Golf! Quote
so:
Typically, the warning lamp was connected to the ignition positive. The other side went to the oil pressure switch. When the oil pressure was too low, the switch would connect its connection to ground, and the lamp would light up. -> The switch has a connection when the engine is stationary.
'Something has changed recently. The instrument panel applies 12V to the line going to the oil pressure switch. The switch now activates and connects to ground when there is sufficient oil pressure. If the line is not connected to ground, the oil pressure warning light comes on. -> The switch does not have a connection when the engine is stationary.'
Advantage of this circuit: Cable breakage is reliably detected!
Just connect a multimeter to the switch if you're unsure.
See you, Gremlin
Animalking
Post10-09-2002, 12:19    Subject: Oil pressure sensor in the Golf! Quote
Received today from VDO:
Based on our knowledge, the oil pressure warning light briefly illuminates when the ignition is turned on and at the latest when the engine starts.
If the oil pressure light is still on even when the engine is running, it's possible that the wrong switch has been replaced.
For any further questions, please do not hesitate to contact us.
Best regards
Uwe Hofmann
Siemens VDO Trading GmbH
Hmm, if I simply disconnect the sensor cable for the oil pressure warning indicator and leave it hanging loosely, the warning light will NOT beep when the ignition is turned on, however, if I start the engine and drive for about 1 minute, it will beep. If I now attach the cable to the VDO unit, it starts making noise even with the ignition on and it doesn't stop!!!
Post10-09-2002, 12:31    Subject: Oil pressure sensor in the Golf! Quote
@Animalking
Zefix, please finally measure the old oil pressure switch and the VDO oil pressure switch to determine whether it's an open or closed circuit! Then check the switches and that's it!
Where is the problem? Did you throw away the old oil pressure switch? -> Bad...
Animalking
Post10-09-2002, 12:55    Subject: Oil pressure sensor in the Golf! Quote
Yes, the master is gone!
P.S: Don't be so mean icon_cry.gif
Animalking
Post13-09-2002, 19:08    Subject: Oil pressure sensor in the Golf! Quote
So habe den Geber nun ausgemessen!
When the engine is stationary and the ignition is switched on, the sender switches to ground. However, when the engine is running, it works exactly the opposite!
Should I now replace the donor?
When the ignition is off, the light turns on, and when the engine is running at idle, it does NOT light up! However, if the engine speed exceeds 2000 and the oil pressure reaches approximately 5 bar, the light will illuminate again, but it will go out after the engine speed is reduced again!
No new posts Golf 4 Fault Code Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf IV 1.9 TDI AXR - Stutters under load Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 5 1.4 BUD Misfire 2. Cylinder Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Oil pressure sensor VW/VDO On-Board Diagnostics (OBD)
No new posts Thread for oil pressure gauge? Diesel Engine Technology
No new posts Tacho Golf 3 an 6-GangGetriebe aus Golf 4-> kein Signal ? Diesel Engine Technology
No new posts Golf 2 GTD/16V: Brake Caliper & Wheel Bearing Mount Transmission, Chassis, Body & Interior
