VP37 ESP: Hot Start Lock - Is There a Solution?
morti850tdi
Post07-11-2005, 11:41    Subject: VP37 ESP: Hot Start Lock - Is There a Solution? Quote
'Does anyone have knowledge about the maximum operating temperature of Bosch ESPs, specifically I'm interested in the VP37?'
I'm specifically interested in whether there are any watchdog mechanisms that, if a temperature threshold is exceeded, for example, reduce performance or prevent the engine from starting.
Is such a regulation integrated into the ELAB system? This would, for example, explain why some TDIs that have been run hot can only be started after a cooling-down period.
Translated on 20-10-2026, 4:37.
Post07-11-2005, 12:56    Subject: VP37: Max. Operating Temperature Specification Quote
morti850tdi wrote:
Is such a regulation integrated into the ELAB? This would, for example, explain why some heavily stressed TDIs can only be started after a cooling-down period.
The ELAB itself is just a simple electromagnet.
However, the resistance of its copper winding increases with temperature, meaning that the hotter the pump, the lower the current and the smaller the opening force of the valve.
While this certainly won't intentionally create a hot-start lock, if significant voltage drops occur due to worn cables/connectors, etc., it could very well happen that the valve no longer opens above a temperature X.
Translated on 20-10-2026, 4:38.
morti850tdi
Post07-11-2005, 13:11    Subject: VP37 ESP: Hot Start Lock - Is There a Solution? Quote
Okay, so ELAB is definitely out of the running.
'In my opinion, the only remaining possibility is the fuel temperature sensor, which might be reporting an excessively high temperature to the control unit, causing it to prevent the engine from starting (perhaps by not activating the ELAB?). Are such control loops common?'
Translated on 20-10-2026, 4:39.
Post07-11-2005, 13:57    Subject: VP37 ESP: Hot Start Lock - Is There a Solution? Quote
morti850tdi wrote:
Are such feedback loops known?
If you mention that some high-performance TDIs only start after a cooling-down period, then there is certainly something else behind these "regular" problems (see, for example, technical articles about starting problems).
If there were a constructive hot start lock, it would presumably
affect all (type-identical) TDIs once certain limits are exceeded.
Translated on 20-10-2026, 4:40.
morti850tdi
Post07-11-2005, 16:14    Subject: VP37 ESP: Hot Start Lock - Is There a Solution? Quote
From your response, I understand that there is no constructive hot-start lock.
That's also my opinion, I just wanted to get another perspective.
I actually experienced the same problem with the engine not starting when it was hot. Cleaning the ELAB (Electronic Load Amplifier) resolved the issue; it seems that it tends to stick slightly at a certain temperature, which blocks the fuel flow.
Translated on 20-10-2026, 4:41.
rinderwahnsinn
Post07-11-2005, 17:41    Subject: VP37: Max. Operating Temperature Specification Quote
Does anyone have knowledge about the maximum operating temperature of Bosch ESPs? I'm specifically interested in the VP37.
Ambient temperature: -20°C to +125°C.
Maximum fuel temperature for continuous operation: <= +95°C.
The EDC reduces the maximum load. Warm-up and hot-start problems have already been extensively described and resolved in this context. Regardless of this, electrical problems can of course occur, such as contact issues in hot environments, etc.
ELABs or signal boxes can also seize up when they are hot. The ELAB in this location has caused problems on several occasions.
Translated on 20-10-2026, 4:42.
Post08-11-2005, 8:59    Subject: VP37: Max. Operating Temperature Specification Quote
rinderwahnsinn wrote:
ELAB devices or signal boxes can also seize up when they are hot. The ELAB has caused problems here on several occasions.
Is there a way to narrow down the susceptibility to these types of issues based on technical articles (e.g., year of manufacture, engine code, mileage, etc.)?
Translated on 20-10-2026, 4:44.
morti850tdi
Post08-11-2005, 10:43    Subject: VP37 ESP: Hot Start Lock - Is There a Solution? Quote
Okay, so my ESP was manufactured in 1996 and it started having problems, but the first time was in 2004.
However, I believe that the issues with the ELAB clamps are less likely to be caused by manufacturing defects and more likely to be caused by contamination.
No new posts Starting problems and glow plug system issues in TDI engi... Technical Articles
No new posts Disassembling the metering unit of a VP37 Troubleshooting & Guides
No new posts Repair of a VP37 manifold Troubleshooting & Guides
No new posts Is there actually a compatibility list...? Diesel Engine Technology
No new posts Is there a German VAG version available for download anyw... Diesel Engine Technology
No new posts Light Relay: Does it Exist? Diesel Engine Technology
No new posts Blue P21W Bulbs: Are They Available? Transmission, Chassis, Body & Interior
