Audi A6 Longlife Service: Anzeige Problem
Spanky
Bertil likes this.
Post20-11-2005, 9:54    Subject: Audi A6 Longlife Service: Anzeige Problem Quote
Hello!
I've been reading here for a long time, and now I have a problem that I'd like to discuss.
Es geht um einen 2003er Audi A6 mit Pumpe Düse Motor AVF(96kw 1,9l) ist ziemlich neu 34tkm! He has long-life [oil/battery/etc.]!
He had the service done at 20,000 km, and now the service indicator is already flashing.
I immediately checked it using the professional CAN USB diagnostic system I bought, specifically on channel 17.
But it all fits: mileage 13,900 km.
abgel. Day 446.
Days: Maximum 730.
km, maximum 50,000.
min. 15,000 km
Oil quality: Grade 4.
It's also strange that the service booklet specifies a maximum of 30,000 km for this engine, contrary to the 50,000 km stated elsewhere.
Why is the light turning on?
Thank you in advance!
Spanky.
Translated on 26-09-2026, 6:51.
D.
Post20-11-2005, 15:35    Subject: Audi A6 Longlife Service: Anzeige Problem Quote
Most likely, the system calculated the exchange rate at that moment based on the collected data.
I also drive a 1.9 TDI with 96 kW and I'm also not getting more than about 12,000-13,000 kilometers per tank.
Since I need more than a year to complete this journey, I don't want to switch to a fixed schedule.
Best regards, D.
Translated on 26-09-2026, 6:52.
Ross-Tech-Support
Post20-11-2005, 15:46    Subject: Audi A6 Longlife Service: Anzeige Problem Quote
D. wrote:
I also drive a 1.9 TDI with 96 kW and I also don't get more than about 12,000-13,000 km.
How is that possible? If the minimum interval is 15,000 km?
Or will you reach 15,000 kilometers before the 24-month period?
Translated on 26-09-2026, 6:54.
Post20-11-2005, 16:29    Subject: Audi A6 Longlife Service: Anzeige Problem Quote
It's interesting to note that some people have a real problem understanding their instruction manual.
It actually states that a long-life service interval (depending on operating conditions) lasts for at least 15,000 km or 12 months. With 446 days, the latter is likely the determining factor.
The vehicle can be driven for a maximum of 50,000 km (for the diesel engine, 30,000 km for the gasoline engine), or for 2 years. Any combination of mileage and time within those limits is possible.
Okay, with just over a year of use and under 15,000 kilometers, you're right in that range, and everything is correct.
More details: http://www.longlife.beetle24.de/
Is the LongLife inspection due already after 15,000 km or less than 2 years?
Yes, with a high proportion of short trips or heavy use, the maximum values are far from being reached. The minimum maintenance interval is 15,000 km or 1 year.
Translated on 26-09-2026, 6:57.
D.
Post20-11-2005, 19:40    Subject: Audi A6 Longlife Service: Anzeige Problem Quote
Thank you, Bertil, for answering the question I asked.
By the way, I'm reading this correctly, but it certainly wasn't addressed to me icon_biggrin.gif.
By the way: Why do you only have a small number of points in your Karma score?
Best regards, D. - who always appreciates your answers very much.
Translated on 26-09-2026, 7:01.
Spanky
Post20-11-2005, 19:51    Subject: Audi A6 Longlife Service: Anzeige Problem Quote
Thank you very much!
Of course, I can already read, but it's difficult because it's a customer's car and there's no owner's manual available.
I was just surprised to see that even the limit for long-life products is only 1 year.
Spanky.
Translated on 26-09-2026, 7:02.
Post20-11-2005, 20:09    Subject: Audi A6 Longlife Service: Anzeige Problem Quote
D. wrote:
Thank you, Bertil, for answering the question directed at me.
... Yes, that's how it was...
I happened to answer your question along the way.
Ask Rainer... he's the only one who can distribute PS points to us... icon_wink.gif But I'm not complaining.
Best regards, D. - who always greatly appreciates your answers.
Thank you icon_redface.gif.
Spanky wrote:
I can certainly read, but since it's a customer's car without an owner's manual, it's difficult.
... But above, you are writing about the service booklet... it's also included in there. icon_wink.gif
Translated on 26-09-2026, 7:06.
Spanky
Post20-11-2005, 20:28    Subject: Audi A6 Longlife Service: Anzeige Problem Quote
Bertil, you got me!
I will definitely pay more attention in the future and read it very carefully!
I can definitely sleep soundly now, thank you again!
Spanky.
Translated on 26-09-2026, 7:08.
No new posts Audi Longlife Service: Your Best Choice Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Some information about the longlife service Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi Service Interval Display / Maintenance Indicator Technical Data
No new posts Long Life Service: Your Car's Extended Warranty On-Board Diagnostics (OBD)
No new posts Passat Longlife Service: Every 15,000 km? On-Board Diagnostics (OBD)
No new posts Reset Service Light: Won't Turn Off? On-Board Diagnostics (OBD)
No new posts Service zurücksetzen Audi A3 8p On-Board Diagnostics (OBD)
