OlliP Guest
04-10-2002, 12:40 Subject: VAG Com - Easily make adjustments |
I got a demo version of VAG-COM and I want to...
Let's just make a change to add some feeling.
to get involved in the matter. I have selected the following for this purpose.
The central locking system!!! I would like to set up that...
The control valve closes after the system has reached its operating pressure. Of course, I don't want anything.
'I'm going to break something and I'm asking here first!'
Is there a guide for that?
Thank you.
Olli.
DocSnydor Guest
04-10-2002, 14:20 Subject: VAG Com - Easily make adjustments |
Small tip: Check the error database (2. Page ) under 'Central locking system adjustment options' or something like that...
OlliP Guest
07-10-2002, 12:54 Subject: VAG Com - Easily make adjustments |
'Thank you.' I've looked at everything, but I'm still unsure.
Not quite so sure!!!
1. Will this also work on my Seat Leon, manufactured in 2002?
2. Is this also 'Olli-Sicher'?
CU
Olli.
Joined: 04/12/2002 Posts: 18098 Karma: +799 / -0 Location: St.Gallen 2018 Volkswagen T6
07-10-2002, 15:05 Subject: VAG Com - Easily make adjustments |
Practice makes perfect...
Profile PM WWW Garage |
OlliP Guest
10-10-2002, 22:14 Subject: VAG Com - Easily make adjustments |
...and then the 'this is going to be expensive' light comes on???
Thank you.
Olli.
DocSnydor Guest
11-10-2002, 8:25 Subject: VAG Com - Easily make adjustments |
I would say, then it's better to just not do it...
OlliP Guest
11-10-2002, 11:24 Subject: VAG Com - Easily make adjustments |
THANK YOU for the encouragement!!
Do the Audi parts fit my SEAT?
CU
Olli.
Michael II Profi-Schrauber
Joined: 04/12/2002 Posts: 1132 Karma: +3 / -0 Location: Stuttgart
11-10-2002, 11:40 Subject: VAG Com - Easily make adjustments |
The data from Audi (usually encoded using control unit codes) is not the same as the data from VW (usually encoded using adaptation channels).
As you may already know, SEAT is concerned about... The technology is closer to Volkswagen than to Audi.
Therefore, you should try the Volkswagen approach.
If you don't have enough experience and knowledge yet, you should probably spend some more time browsing this forum before you start trying things out. Tschüss
Michael II
OlliP Guest
11-10-2002, 12:07 Subject: VAG Com - Easily make adjustments |
That is not correct!!
My LEON is (almost) an A3, and SEAT is a subsidiary of AUDI.
SKODA is a subsidiary of VW!
AUDI - SEAT - Lamborghini
VW - SKODA - Bentley
This is what the corporate structure looks like!
Correct me if I'm wrong.
CU
Olli.
11-10-2002, 12:35 Subject: VAG Com - Easily make adjustments |
Unfortunately, the corporate structure (which, by the way, hasn't been in this form for very long) is not reflected in your engine control unit (ECU) coding. Tschüss
Michael II
OlliP Guest
11-10-2002, 12:56 Subject: VAG Com - Easily make adjustments |
Okay, clear statement.
Does that mean I can use the VW data?
12-10-2002, 11:17 Subject: VAG Com - Easily make adjustments |
Hi Olli,
It doesn't necessarily work for every car. For example, in the Ibiza 6K, it doesn't work with either the VW or Audi codes to access the central locking module, because, according to Michael II, it's not connected to the K-bus. Someone already asked about the Leon in the auto-intern forum, but as far as I know, it didn't lead to any results.
Do you actually see the ZV module with VAGCOM?
Otherwise, I agree with Michael; almost everything else about the Ibiza is very VW-like.
Jan. 1Z5 CFHF  / AHB H4D
OlliP Guest
12-10-2002, 20:27 Subject: VAG Com - Easily make adjustments |
Okay, so I've tried it all out now!
Michael is right - VW works.
And Rainer is, of course, also right.
TRY AND SEE! (or TRY AND FIND OUT!)
/Happy one
IT WORKS.
/Happy out
CU
Olli.
