Error code reading
hdim
Post20-11-2005, 9:03    Subject: Error code reading Quote
Hello friends,
Please help with the error code display: Audi A6 C5, error code 01336, "Communication bus, data bus, comfort system" shows "37-00", indicating a fault. Can anyone tell me what this is?
Thank you very much.
Hans.
bafische
Karma: +22 / -0   Thank you, like it!
Post21-11-2005, 21:24    Subject: Error code reading Quote
There's a fault in the comfort CAN bus (the communication line for various comfort functions such as central locking/power windows/interior lighting/mirror heating, etc.). Specifically, it's a broken wire, a short circuit to ground or positive, or a data line fault within the bus system.
The following is possible:
Short circuit between the data lines of the bus system.
The data lines of the bus system are reversed.
"A control unit connected to the bus system corrupts the transmitted data telegram, for example, the gateway or the comfort/door control units."
"Luft und Menge müssen stimmen - der Rest ist Physik."
unumstössliches Gesetz in der Dieselmotorenentwicklung
hdim
Post21-11-2005, 22:01    Subject: Thank you very much for your help, I'm going to start testing Quote
Greetings
vagtuning
Post21-11-2005, 22:15    Subject: Error code reading Quote
Are there any other systems where errors are intentionally programmed in?
It would also be interesting to know the part number and software version of the control unit that is reporting the error.
hdim
Post22-11-2005, 8:38    Subject: Error code reading Quote
vagtuning wrote:
Are there any errors stored in any other system?
Providing the part number and software version of the TCU (Transmission Control Unit) that is reporting the error would also be interesting.
Yes, the address is 35 Zentakverr. Control unit 4B0 962258 D, coding 06721, 3 intermittent errors.
01561 (Door H 59-00L), 015662 (Door HR 59-10), 01562 (Door HR 61-10)
However, I have never been able to detect any errors in practice.
Hans.
No new posts Error code P1351 General Tips
No new posts Error code 01276 - ABS hydraulic pump (V64) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ESP function test, error code 01486 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VAG Data Reading, Evaluation, and Injection Start Timing On-Board Diagnostics (OBD)
No new posts Error code Diesel Engine Technology
No new posts 2.5 TDI Error Codes: AAT & More Diesel Engine Technology
No new posts Error Code 65535: Troubleshooting Guide On-Board Diagnostics (OBD)
