Passat TDI Flywheel: AFN Engine, 1998 Model.
KimR
Post24-11-2005, 23:39    Subject: Passat TDI Flywheel: AFN Engine, 1998 Model. Quote
Hello!
Does anyone here know if a flywheel from a PDI engine, for example, with 115 HP or 130 HP, will fit in my car?
Vehicle data:
Passat 3B TDI Variant, manufactured in 1998.
MKB AFN engine with 5-speed manual transmission.
Front-wheel drive.
According to my information, the diameter of PDI products is 240mm, whereas mine is 220mm.
'Will a larger 240mm fan fit on my kW? And is there enough space for the ZMS (presumably referring to a clutch or flywheel) inside the transmission housing?'
'Of course, I can reassemble a ZMS series. However, I would really prefer a stronger one that can handle more torque.'
Translated on 28-09-2026, 7:27.
Post26-11-2005, 9:44    Subject: Passat TDI Flywheel: Replacement & Repair (98) Quote
KimR wrote:
... Of course, I can reassemble a series of ZMS.
But I would really prefer a stronger one that can handle more torque. http://webcat.zf-trading.com/
} -> When searching, check the box next to the manufacturer "SRE". This will also display the reinforced clutches from Sachs.
Translated on 28-09-2026, 7:29.
No new posts Install Parking Heater in VW Passat 3BG Troubleshooting & Guides
This topic is locked, you cannot edit or reply. Passat 3BG 2005 Door Opening Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat MKB AVB: Fuel Leak Diagnosis & Repair Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Rear-wheel drive VW Passat, manufactured in 1998 Diesel Engine Technology
No new posts Oil Leak: A4 B5 2.5 TDI (1998) - Fix It! Diesel Engine Technology
This topic is locked, you cannot edit or reply. A6 TDI 2,5L 110kw BJ98 ESP defekt Diesel Engine Technology
No new posts Ford Galaxy BJ98 Diesel Engine Technology
