ABS Problems: Causes and Solutions
halali
Post25-12-2005, 1:02    Subject: ABS Problems: Causes and Solutions Quote
Hello everyone.
I'm having a problem with my VW Passat 1.9 TDI. Both the drive shaft boots were torn, and I had them replaced. Since then, whenever I brake, I sometimes hear noises like I'm braking on snow. It doesn't happen often, but when I press the brake pedal while rolling, I sometimes hear a humming sound coming from the engine compartment. Can anyone help me with this?
Translated on 17-08-2026, 5:52.
vagtuning
Post25-12-2005, 1:17    Subject: ABS Problems: Causes and Solutions Quote
Hmm, could the ABS rotor have been damaged during installation or removal?
That would be the initial assumption.
Translated on 17-08-2026, 5:53.
bloesch
Post25-12-2005, 3:30    Subject: ABS Problems: Causes and Solutions Quote
Or the ABS sensors were not pulled out far enough before removing the drive shafts and are now damaged.
mullemaus
Post25-12-2005, 14:54    Subject: ABS Problems: Causes and Solutions Quote
Okay, try removing the sensor and see if any dirt has accumulated at the tip. If there is, remove it. To do this, rotate the wheel and examine the ABS ring in the hole (for a complete rotation). You should be able to find it then. icon_wink.gif
Translated on 17-08-2026, 5:54.
halali
Post05-01-2006, 17:55    Subject: ABS Problem: Troubleshooting & Solutions Quote
Good day everyone.
I would like to sincerely thank you for your numerous responses. As you have already mentioned, the sensor was slightly dirty.
and the problem is solved.
No new posts AGR Problems: 1.4 16V Gasoline Engine Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Cruise Control Installation Problems Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document A2 8Z0 MJ 2002, Problems with the Main Control P... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Probleme mit der ASU Diesel Engine Technology
No new posts 2.5 TDI AAT Problems: Common Issues & Fixes Diesel Engine Technology
No new posts ALE: Troubleshooting GRA Issues in MKB Diesel Engine Technology
No new posts 2.5 TDI +++ Probleme Diesel Engine Technology
