marcello Schrauber
Joined: 01/22/2003 Posts: 26 Karma: +0 / -0 Location: südtirol
15-12-2005, 19:42 Subject: ESP Pinout Audi 80 TDI |
Hello everyone.
Yesterday, I was planning to install an Audi fuel injection pump (with HDK) into a Golf 3.
Problem: The Audi ESP has a round connector, while the Golf has a rectangular one. So, I soldered together an adapter connector and connected the pin numbers exactly as they should be.
Unfortunately, the Golf wouldn't start. Both ESP units, which are from the 1Z platform, have the same part numbers (except for the last letter). The error codes stored in the system are: fuel temperature sensor and fuel quantity control unit. Based on this, I suspect that the fuel injection pump is incorrectly connected, because it was working perfectly fine in the Audi.
Does anyone happen to know the pinout for a 1Z pump with a round connector?
I would be very grateful.
Best regards, Marcello.
Translated on 01-10-2026, 5:00.
Profile PM Email |
wolfi_b Profi-Schrauber
16-12-2005, 8:05 Subject: ESP Pinout Audi 80 TDI |
Let me guess: the pump from the Audi is a 028 130 109 J.
"Did you not find it strange that the pump had a different connector and a different part number?"
The last letter belongs to the part number and is extremely important!
The pump with the round connector doesn't have an HDK; it has a potentiometer!
That can't work.
1993 Audi 80 B4 1Z
2004 Seat Leon 1M ASV
Translated on 01-10-2026, 5:01.
marcello Schrauber
16-12-2005, 12:37 Subject: ESP Pinout Audi 80 TDI |
"No, it doesn't have the pot. That was only on the first models that had the return hose on the top of the flow meter (1992-1993). Mine already has the HDK (vent screw located on the side of the flow meter)."
Translated on 01-10-2026, 5:02.
Profile PM Email |
16-12-2005, 16:30 Subject: ESP Pinout Audi 80 TDI: Wiring Diagram & Info |
marcello wrote: | | Does anyone perhaps know the pinout of a 1Z pump with a round connector?? | Hi,
I don't know her, but I would measure the whole thing.
The MSW likely has the lowest resistance, the temperature sensors have the highest, and the RWG (with 3 connections) provides intermediate values.
The polarity of the MSW (motor starter switch) doesn't matter, and the polarity of the sensor is irrelevant in any case.
You may have to try several times with the RWG before it works. However, I don't think anything should break in the process.
Translated on 01-10-2026, 5:03.
Profile PM Garage |
JRoth Blaumann
Joined: 06/23/2002 Posts: 19 Karma: +6 / -0 Location: Willich
16-12-2005, 23:24 Subject: Pump Connector Pinout: Explained & Diagram |
Passat Variant 35i 1Z 05/02 - 01/05
Ford Galaxy AFN 01/05 -07/06
Ford Galaxy 08/06 - 08/09
Translated on 01-10-2026, 5:04.
17-12-2005, 12:28 Subject: Pump Connector Pinout: Explained & Diagram |
JRoth wrote: | | How about it here with | ? These are the pin assignments for the oval connector, but this is about the (exotic) round one... if they were the same, Marcello probably wouldn't have a problem  .
Translated on 01-10-2026, 5:05.
Profile PM Garage |
JRoth Blaumann
17-12-2005, 13:40 Subject: ESP Pinout Audi 80 TDI |
 I realized it later too...
JRoth
marcello Schrauber
17-12-2005, 14:03 Subject: ESP Pinout Audi 80 TDI |
"Does anyone really have the pinout for a round connector or a circuit diagram?"
Please help me.
Translated on 01-10-2026, 5:06.
Profile PM Email |
Rudi Guest
17-12-2005, 14:22 Subject: ESP Pinout Audi 80 TDI |
Hello Marcello,
Are you absolutely sure that you have an ESP system with an HDK sensor?
I went through my old documents and even the oldest A4 paper I found...
HDK (MJ '95 - i.e., starting around September '94) already has the 'standard' eight-pin connector.
Connector with the following pinout:
1: G149 (HDK) Reference
2: G149 Common
3: G149 Signal
4: G81 (Fuel Temperature) Mass.
5: N146 (Quantity adjuster) Control (mass).
6: N146 Supply +
7: G81 Signal.
8: free.
The old Potigeber positions were filled as follows:
1: G99 (Poti) Grinder (meaning signal).
2: G99 Power Supply.
3: G99 Power Supply (other end of the track resistance).
4: N146 Supply +
5: N146 Control (Mass).
6: G81 Signal.
7: G81 Supply (+?)
Rudi
Translated on 01-10-2026, 5:08.
marcello Schrauber
17-12-2005, 22:35 Subject: ESP Pinout Audi 80 TDI |
Hello.
We're talking about the Audi 80 with an HDK engine, because I've never seen an A4 with a 1Z engine. But still, thanks for your effort (I'm still not any further though).
Translated on 01-10-2026, 5:10.
Profile PM Email |
Rudi Guest
17-12-2005, 23:14 Subject: ESP Pinout Audi 80 TDI |
The A4 model was available with a 1Z engine and HDK starting in 1995.
What is the part number of your pump?
Rudi
marcello Schrauber
20-12-2005, 18:51 Subject: ESP Pinout Audi 80 TDI |
Apologies for the late reply. The EP has the number 028130109L.
Profile PM Email |
guste100 Profi-Schrauber
Joined: 07/27/2004 Posts: 2406 Karma: +441 / -0 Location: Mitte Schleswig Holsteins 2007 Volkswagen Passat Premium Support
20-12-2005, 19:35 Subject: ESP Pinout Audi 80 TDI |
Hi Marcello,
I don't have the pinout, but I do have the following information: The part number 028130109L was replaced by ...115NX, which was used in the 80/90 and Avant models from 1994-1996, and in the Cabrio models from 1992-2000. This corresponds to a Bosch part number: VE4/10E2250R530-1.
All the Bosch ECUs I know of from the early 1Z models with HDK are VE4/10E2250R510-X (with 510 instead of 530). (And later, 590 instead of 510, for example, ALE). This also suggests that yours is not an HDK pump. To my knowledge, the connector is also an indicator of this.
Just unscrew the top cover of the MSW, and you'll see it immediately. Especially for you, as the author of the MSW disassembly guide (thank you for that!), that should be the easiest thing to do.
Guste.
Translated on 01-10-2026, 5:12.
Profile PM Garage |
20-12-2005, 20:31 Subject: ESP Pinout Audi 80 TDI |
guste100 wrote: | | Just unscrew the top cover of the MSW, and you'll see it immediately. | . . . or, if you have a multimeter handy, simply measure the resistance between pins 1 and 3: The HDK sensor has only a few ohms (which don't change when voltage is applied to the MSW), while a potentiometer sensor would have a significantly higher resistance due to power loss during operation, estimated to be in the kOhm range.
Warning: Do not apply full battery voltage to the MSW for testing, as this could cause it to spark violently and burn out quickly. Instead, use a turn signal or headlight bulb in series.
Translated on 01-10-2026, 5:14.
Profile PM Garage |
