Continental Winter Tires
Go to page: 1, 2, 3  Next
Post14-02-2005, 9:38    Subject: Continental Winter Tires Quote
Has anyone heard anything about whether Conti is planning a successor to the TS 780?
The TS790 was replaced by the TS810 this winter.
However, there have always been new models introduced in pairs in the compact and mid-size segments.
760/770 -> 780/790, but now 780/810.
I really need to get new tires now, but I'd rather not take the old 780s off if I'm getting new ones for next winter.
Who knows anything about this?
Logically, the designation "TS800" would make sense, and I can find some information about it online, although not from Conti.
Translated on 28-08-2026, 14:44.
Post14-02-2005, 9:58    Subject: Continental Winter Tires Quote
The designation is likely already registered.
http://www.patent.gov.uk/tm/tmj/journals/6533/madrid/821962.html
And here, it appears that a TS800 is also being discussed, if it's not a typo (image on the left) http://www.autoreview.ru/new_site/year2004/n24/conti/1.htm.
Translated on 28-08-2026, 14:45.
Post14-02-2005, 10:27    Subject: Continental Winter Tires Quote
Thank you, Roger.
I also found the patents, but I couldn't find the Russian image.
http://www.autoreview.ru/new_site/year2004/n24/conti/800/04.jpg
If it were a printing error, it would be a very good one, because the tire model name is clearly visible on the tire!
So, it will be released in the winter of 2005 - why not now?
Translated on 28-08-2026, 14:46.
Post14-02-2005, 10:37    Subject: Continental Winter Tires Quote
Why not now
Possible explanation:
Especially in the automotive sector, German industry often supplies foreign markets first – the domestic market is rightly considered to be very demanding.
"Better to have a setback abroad and then quickly make improvements, than to damage your reputation in Germany."
Translated on 28-08-2026, 14:47.
Post14-02-2005, 10:44    Subject: Continental Winter Tires Quote
That could be true.
On the other hand, it can also be the case from an economic perspective:
Germans are really into the excellent TS780. Why not make some money with it first, especially since the competition doesn't offer anything comparable that's in high demand? ...And first, clear out the existing stock.
Okay, I guess I'll just keep using my crappy Uniroyals for now, drifting with the G3 Variant really gets my adrenaline pumping. icon_evil.gif
Translated on 28-08-2026, 14:48.
olli
Karma: +46 / -0   Thank you, like it!
Post14-02-2005, 18:50    Subject: Continental Winter Tires Quote
The driving characteristics of the Contis are excellent, but you can forget about their durability.
We had both TS780 and TS790 tires on A6 and Passat cars, and after two winters, we noticed cracks between the tread blocks on the tire surface.
According to the tire dealer (the same one who sold them previously), this is perfectly normal for tires. However, you should definitely not continue driving on these tires, as the cracks can expand due to moisture and freezing.
Interestingly, the Conti summer tires on the Passat (3 years old or 30,000 km driven) showed the same effect.
We've now moved on to Michelin tires; when it comes to summer tires, opinions are very divided regarding their performance in wet conditions, but the winter tires, at least on my A6, perform equally well and are also quieter than the Contis.
Olli.
A6 CANA/JME /
Ex-A6 AEL
Translated on 28-08-2026, 14:50.
Julian
Post14-02-2005, 20:01    Subject: Continental Winter Tires Quote
But you can forget about its durability.
I am unable to confirm this information based on data from multiple vehicles with different TS760, TS770, and TS790 configurations.
The TS760 didn't particularly like powerful vehicles or temperatures above 7°C, and it tended to become unstable. However, based on my experience, the 770 and especially the 790 are completely unaffected and last a very long time.
'Of course, it always depends on the tire pressure and driving style.'
Translated on 28-08-2026, 14:51.
x world one
Post15-02-2005, 10:04    Subject: Continental Winter Tires Quote
olli wrote:
We've now switched to Michelin tires; when it comes to summer tires, opinions are very divided regarding their performance in wet conditions, but the winter tires at least perform equally well on my A6, and they are also quieter than the Contis.
I also have Michelin Alpin A2 tires for the winter. I think they are a great tire, with very good grip on snow, ice, and dry roads. However, my summer tires are significantly better in wet conditions.
Spritmonitor
Translated on 28-08-2026, 14:52.
Wurstblinker
Post23-02-2005, 13:36    Subject: Continental Winter Tires Quote
Olli
That's exactly what happened to my Conti 790!
'They were 3.5 years old and had countless cracks, which, according to my tire dealer, made them unsafe for driving. I didn't want to drive them on the highway anymore. It's a known problem. However, if you use the tires for only two winters, it's probably not a problem.'
I complained to Continental extensively and received a credit!
I then got myself a set of Dunlop WinterSport M3 tires!
So far, I'm very, very satisfied! I recently used it in Austria, and it worked everywhere.
My brother uses these tires on his Golf 4, and my dad uses them on his A4, and they haven't had any issues either.
Furthermore, my brother could also discard his Conti EcoContact tires, as they were very cracked, although they still had good tread.
Translated on 28-08-2026, 14:54.
herwigw
Post23-02-2005, 17:31    Subject: Continental Winter Tires Quote
Olli
'They were 3.5 years old and had countless cracks, which, according to my tire dealer, made them unsafe for driving. I didn't want to drive on the highway with them anymore. It's a known problem. However, if you only use the tires for two winters, it's probably not a problem.'
Regards
Have I already said in this thread that I consider my Dunlop WinterSport M3 tires to be the best? icon_biggrin.gif
They are incredibly quiet, perform well in all areas, and are not nearly as expensive as brands like Michelin.
(Maybe I'll get something from Dunlop for this.)
This year, you're starting your second winter, but I'll pay particular attention to any cracks when I change them, especially since these kinds of defects are becoming fashionable again with some brands. I would have expected to see this only on retreaded tires.
best regards
herwig
Translated on 28-08-2026, 14:58.
Wurstblinker
Post23-02-2005, 21:46    Subject: Continental Winter Tires Quote
Yes, they are very quiet indeed!
But even on wet roads, I always have a particularly secure feeling while driving!
Okay Martin, forget about the Conti, save a few euros and get the M3!
Translated on 28-08-2026, 15:01.
vagtuning
Post23-02-2005, 23:15    Subject: Continental Winter Tires Quote
I can't complain about Contis; I have the TS 810 tires, and they run wonderfully quietly and smoothly, and so far, they offer excellent grip.
Theresias
Post24-02-2005, 2:19    Subject: Continental Winter Tires Quote
Regarding the tire performance, it's interesting. Initially, I had a set of Pneumant 100 tires, then a set of re-grooved, non-brand winter tires, and now I have Conti TS790 tires.
The Pneumant tires were by far the quietest, and they also provided good contact with the road, although it felt like the TS790 tires had better grip. However, the retreaded tires were extremely loud and unbearable at 180 km/h, even though they were rated up to 190 km/h. Their grip was absolutely terrible; they would spin immediately even with the slightest acceleration.
Let's see what comes after the Contis.
Translated on 28-08-2026, 15:02.
Wurstblinker
Post24-02-2005, 13:05    Subject: Continental Winter Tires Quote
How old are your Contis?
In the first two years, there should be very few cracks.
But then it usually starts.
Translated on 28-08-2026, 15:03.
Theresias
Post24-02-2005, 13:09    Subject: Continental Winter Tires Quote
But then, it usually starts.
Translated on 28-08-2026, 15:04.
pschaefer
Post24-02-2005, 15:17    Subject: Continental Winter Tires Quote
If this is going to devolve into a general thread about winter tires:
Does anyone actually use Bridgestone LM-18 tires? I think mine are...
They have very little grip (at 2.0 bar). However, they performed better in some tests.
as Conti was cut off...
No new posts Which Conti timing belt kit fits the AFN engine in the VW... Diesel Engine Technology
No new posts Conti SportContact 2: Buy One or Two? Transmission, Chassis, Body & Interior
No new posts Winter tires for VW Polo 9N:-( Transmission, Chassis, Body & Interior
No new posts Winter Tires in Summer: Should You? Transmission, Chassis, Body & Interior
