Diagnosis: Acquisition
Cozmo2010
Karma: +0 / -1   Thank you, like it!
Post29-12-2005, 15:43    Subject: Diagnosis: Acquisition Quote
I would like to purchase a laptop or diagnostic device that allows me to read all error codes.
It's enough if it works with Golf 3 models or later.
Okay, I need some tips and suggestions from you about what I'll need for this.
Sure, here's the translation:
"Thank you in advance."
Gruß, Coschi
Post29-12-2005, 16:23    Subject: Diagnosis: Acquisition Quote
If you want to get everything with just one purchase:
http://shop.dieselschrauber.de/product_info.php/products_id/32
Cozmo2010
Post29-12-2005, 16:49    Subject: Diagnosis: Acquisition Quote
Oops.
I didn't want to spend that much!
Gruß, Coschi
mullemaus
Post29-12-2005, 17:49    Subject: Diagnosis: Acquisition Quote
Then buy a laptop (e.g., on eBay) and, in the shop shown above, purchase an interface and the corresponding software. That will also icon_wink.gif.
Cozmo2010
Post29-12-2005, 18:17    Subject: Diagnosis: Acquisition Quote
Okay... I'd rather do that with a laptop!
What requirements should a notebook meet in order to be suitable for that purpose?
Gruß, Coschi
mullemaus
Post29-12-2005, 18:45    Subject: Diagnosis: Acquisition Quote
A Pentium II should be sufficient. You should pay attention to a good battery. icon_wink.gif
Post29-12-2005, 20:16    Subject: Diagnosis: Acquisition Quote
You can find the hardware requirements here (section 1.4 for serial adapters, 1.5 for USB).
http://www.ross-tech.com/vag-com/faq_1.html#1.4
Cozmo2010
Post29-12-2005, 20:23    Subject: Diagnosis: Acquisition Quote
Okay.
Okay, now I know what kind of laptop I need!
What cables or adapters do I need to be able to use the 2x2 connection in my Golf 3?
and which cables are needed to connect to newer cars?
Gruß, Coschi
Post29-12-2005, 20:59    Subject: Diagnosis: Acquisition Quote
"This isn't a simple question to answer. "Newer cars" often have CAN bus diagnostics and require a CAN-compatible interface, such as the Golf 5, new A3 models, Touran, etc."
All interfaces come with the 16-pin OBD2 connector. For 2x2 sockets, corresponding adapters are available here in the shop http://shop.dieselschrauber.de/product_info.php/products_id/34.
Please note that newer versions of VAG-Com, specifically those above version 3.11, can only be used or unlocked in conjunction with intelligent interfaces that have a built-in dongle.
Cozmo2010
Post29-12-2005, 21:35    Subject: Diagnosis: Acquisition Quote
Okay, then I'll focus on the models up to the year 2000, was probably the limit, right? If so, what do I need?
Gruß, Coschi
Post29-12-2005, 22:23    Subject: Diagnosis: Acquisition Quote
The border is more likely to be from 2003.
You need this (serially).
or this one (USB).
http://shop.dieselschrauber.de/product_info.php/cPath/21/products_id/41{MARKER}
plus this one for your G3.
http://shop.dieselschrauber.de/product_info.php/products_id/45http://shop.dieselschrauber.de/product_info.php/products_id/34
Cozmo2010
Post29-12-2005, 22:26    Subject: Diagnosis: Acquisition Quote
Okay, then I know the basics.
THANK YOU VERY MUCH!
Gruß, Coschi
No new posts DIY OBD Adapter: Build Your Own Diagnostic Tool Troubleshooting & Guides
No new posts Eberspächer Heater Diagnostics: Troubleshooting Guide Troubleshooting & Guides
No new posts VCDS: On-board diagnostics for VAG vehicles Troubleshooting & Guides
No new posts AC Service Equipment: Purchase & Installation Transmission, Chassis, Body & Interior
No new posts OBD Scanner: Buy Interface for Car Diagnostics On-Board Diagnostics (OBD)
No new posts OBD2 Diagnostics for Non-Diagnostic CAN Bus On-Board Diagnostics (OBD)
No new posts VAG Diagnostics: Troubleshooting & Repair On-Board Diagnostics (OBD)
