brezelmann01 Profi-Schrauber
Joined: 09/14/2002 Posts: 714 Karma: +75 / -0 Location: Niedersachsen
14-09-2003, 12:05 Subject: Webasto STH Diagnosis: Troubleshooting Guide |
Hi!
Has anyone had a positive experience connecting their diagnostic adapter to an aftermarket Webasto STH (standing heater)?
When I connect my adapter (the schematic is not from this site, but it works with optocouplers) and start the corresponding diagnostic program, the data from the STH is immediately read and displayed. However, after that, nothing else can be done. It's not possible to erase the memory, send commands, or do anything else. The error message that always appears is "Timeout...".
I'd like to know if this might work better with your adapters, or if you have any suggestions for me?
Thank you.
pretzel
Translated on 01-10-2026, 19:06.
14-09-2003, 15:11 Subject: Webasto STH Diagnosis: Troubleshooting Guide |
small addition:
Problem solved. The cause was that I was working with a DOS window under XP. It seems the heating system didn't like that... It works perfectly fine under "DOS only" mode!!!
See you later.
pretzel
Translated on 01-10-2026, 19:08.
Varianti Guest
15-09-2003, 8:12 Subject: Webasto STH Diagnosis: Troubleshooting Guide |
How did you manage to integrate the Webasto into the VW diagnostic system? Also, what kind of car and heater (aftermarket) do you have?
Translated on 01-10-2026, 19:09.
15-09-2003, 10:14 Subject: Webasto STH Diagnosis: Troubleshooting Guide |
Hello Varianti!
You misunderstood me. I did NOT include the STH diagnosis in the VW diagnosis. The diagnoses are completely separate, and I use different programs for each. It's an aftermarket Webasto unit.
pretzelman01
Translated on 01-10-2026, 19:10.
PrivatBereich Guest
15-09-2003, 10:30 Subject: Webasto STH Diagnosis: Troubleshooting Guide |
(The circuit diagram is not from this page, but it uses optocouplers.)
Hi Brezelmann,
Since many people (including myself) are likely interested in a corresponding circuit and programs for diagnosing Webasto auxiliary heaters, it would be great if you could post a link to the relevant page.
Thank you in advance and best regards.
-Private
Translated on 01-10-2026, 19:12.
christians Profi-Schrauber
15-09-2003, 12:41 Subject: Webasto STH Diagnosis: Troubleshooting Guide |
PrivatBereich wrote: |
Here, there are certainly many (including myself) who are interested in a corresponding circuit and programs for Webasto auxiliary heating system diagnostics | .
Yes, I am also part of that group. Gruß Christian
Translated on 01-10-2026, 19:14.
Varianti Guest
16-09-2003, 10:34 Subject: Webasto STH Diagnosis: Troubleshooting Guide |
I am also immediately part of the group of interested people.
So, how did you do it, and with what?
Possibly also via private message.
Translated on 01-10-2026, 19:15.
16-09-2003, 10:43 Subject: Webasto STH Diagnosis: Troubleshooting Guide |
Hello!
Okay, now I'm going to express my opinion on this:
Okay, I had the schematic diagram for my diagnostic interface saved under the following location back then:
http://www.planetfall.com/~jeff/obdii/
"I found it. I sent Rainer this link, and he took a look at it (I don't really know much about electronics...). Anyway, it seems that this adapter is similar to Ulf's simple adapter. Therefore, Ulf's adapter should also work. Why don't you try it out?"
Was das Programm betrifft, da müßt ihr mal Eure freundliche Bosch-Werkstatt fragen (...oder den Esel). Auf der Webasto DataTop CD ist dieses winzig kleine Dos-Programm zu finden, aber solange Rainer keine "Freigabe" von Webasto hat, kann er dieses natürlich nicht online stellen. VeUnderstandable, right?!
pretzel
Translated on 01-10-2026, 19:16.
17-09-2003, 12:42 Subject: Webasto STH Diagnosis: Troubleshooting Guide |
What is the exact name of the program? As you know, donkeys are not exactly known for being intelligent... Gruß Christian
Joined: 04/12/2002 Posts: 18113 Karma: +800 / -0 Location: St.Gallen 2018 Volkswagen T6
17-09-2003, 15:10 Subject: Webasto STH Diagnosis: Troubleshooting Guide |
Translated on 01-10-2026, 19:17.
Profile PM WWW Garage |
Gremlin Guest
18-09-2003, 12:09 Subject: Webasto STH Diagnosis: Troubleshooting Guide |
That's also the case with Eberspächer...
If you want to have access to diagnostic codes, you need to purchase the large weekly timer.
It can read the codes. Otherwise, only the diagnostic tool is needed.
CU Gremlin.
Varianti Guest
16-10-2003, 12:35 Subject: Webasto STH Diagnosis: Troubleshooting Guide |
Okay, so I now have a cable with an OBDII connector on one end. How do I connect this thing to which connector on the STH? Could someone possibly  take a picture or explain it in more detail?
Translated on 01-10-2026, 19:18.
PrivatBereich Guest
16-10-2003, 17:25 Subject: Webasto STH Diagnosis: Troubleshooting Guide |
Okay, so the ODB connector obviously needs +12V and ground, which you can definitely find in the STH wiring harness.
In addition, the auxiliary heater has a cable that, according to the auxiliary heater installation manual, was described as 'for diagnostics, do not connect' (or similar). I believe the cable was yellow. It should be the only cable of the auxiliary heater (besides possibly the cable for summer mode switching, which I believe is brown and purple) that is not connected.
Since this cable is the only diagnostic cable provided by STH (and therefore doesn't have an L-line), it probably needs to be connected to the K-line of the OBD adapter.
However, I've only come to these conclusions through logical reasoning, and I don't have any practical experience to support them. I hope it's still correct.
Private.
Translated on 01-10-2026, 19:19.
16-10-2003, 20:00 Subject: Webasto STH Diagnosis: Troubleshooting Guide |
That is absolutely correct. Gruß Christian
Translated on 01-10-2026, 19:20.
mgolz Guest
07-02-2006, 22:06 Subject: Webasto STH Diagnosis: Troubleshooting Guide |
*Thread bump*
Can the diagnostic lead of the Thermo Top C (pin 1 of the 6-pin connector) be connected to the K-line (of my VW Passat 3B) to create a diagnostic bus in the car?
wolfi_b Profi-Schrauber
08-02-2006, 9:52 Subject: Webasto STH Diagnosis: Troubleshooting Guide |
No, that's not possible. 1993 Audi 80 B4 1Z
2004 Seat Leon 1M ASV
Translated on 01-10-2026, 19:21.
