Um, I wrote that I want to summarize expert articles and know-how from contributions. The result should be improvement suggestions for the FA.
It's all explained there, and it's quite comprehensive. I wouldn't recommend that people who have absolutely no technical knowledge start tinkering with their cars. It can end up being more expensive than going to an incompetent workshop (which at least can replace parts).
Immobilizer active (engine turns off approximately 1 second after starting):
-> Try other authorized keys; if necessary, have the key repaired or properly programmed.
Defects in the area of the engine temperature sensor:
-> Check with VAG-COM, and if necessary, replace it or repair any damaged cables or connectors.
The valve that shuts off the distribution pump is not opening properly.
-> Measure the supply voltage and resistance (approximately 8 ohms). If these are okay, check for internal connection problems and, if necessary, remove any burrs.
Difficulty in operation or electrical faults in the dosing unit of the VP 37 (often in conjunction with error memory entries):
-> Make it common or replace the pump, or repair the cable.
Other electrical or electronic defects in the area of the Electronic Control Unit (ECU) or wiring harness, relay 109, etc.:
-> inspect and replace / repair.
Starting quantity specified is too low.
-> It is calculated based on temperature and may, depending on the software and the tolerances of the temperature sensor, be slightly low for cold or warm starts. It can be increased using VAG-COM.
Low starter motor speed despite a fully charged battery:
-> If the engine starts immediately when jump-starting or rolling, first clean all the corroded contacts between the battery and the starter.
-> If crimp connections, cable kinks, etc., become hot quickly while playing the organ, replace these cables.
-> If all the cables are in good condition, replacing the starter motor might improve the situation.
However, when reeling in the cable quickly, a (slightly) higher compaction is achieved, which can mask poor compression values. In such cases, replacing the reeling mechanism will not yield any significant improvement.
Weak battery (noticeable by a tired starter motor and, for example, a very dim interior lighting).
-> If a measurement of approximately 0.1 A is taken with an ammeter between a disconnected battery terminal and the battery terminal of a parked vehicle, starting problems may occur after only a few days, and even sooner with higher fault currents. -> Investigate and eliminate faults in the vehicle's electrical system.
-> If the charging voltage at the battery is correct (around 14 volts) while the engine is running, check the acid density, etc., and if necessary, replace the battery.
-> If the voltage is below 13.5 volts, check the cables between the alternator (LiMa) and the battery for kinks, breaks, corrosion, etc., and repair them if necessary.
-> If the cables are okay, check/repair/replace the alternator, including the regulator and charging control.
Incorrect setting of the VP 37 pump (start of injection).
-> see the relevant article.
Flow meter adjusted too lean (VP 37 only).
-> Use VAG-COM to measure the idle fuel quantity. If it is above approximately 6 mg with a warm engine and no electrical consumers or air conditioning turned on, and/or if the engine exhibits noticeably weak performance with slight acceleration at low RPM and load, you can try adjusting the fuel mixture slightly richer (up to just before the point where it starts to stumble), see the 'technical article on the fuel mixture control / RWG' and the error database 'DIY solution for stumbling issues with VP 37 engines'.
Engine control malfunction (e.g., crankshaft timing belt pulley loosened, camshaft timing incorrectly adjusted, errors during timing belt replacement), sometimes in conjunction with incorrect pump adjustment.
-> Have it corrected or repaired.
Compression loss / Wear on the clamping jaws.
-> For a preliminary check, see 'Used Car Tips'. A more thorough compression test may be necessary, and repairs should be carried out based on the results.
Other defects or excessive wear in the area of the pump and injectors; heavy deposits in the injection system due to poor fuel / biodiesel, etc.:
-> Replace or have the affected parts cleaned.
Fuel with a cetane number that is too low, and sulfuration caused by excessively low outside temperatures.
-> Drain/siphon (including pump) and fill with the correct diesel fuel.
I think that in this forum, there are many people who are not fully knowledgeable, and something like this would be helpful to them and to me.
They are invited to read along and study the technical articles. And it's best to do that before they send the car's fax.
But no problem, we'd rather answer the question about why the engine is hard to start individually every week.
As you (perhaps by chance?) correctly identified, the forum is the place for individual questions. Standard topics are covered in the articles and in older threads (use the search function – it's a powerful tool).
I wanted to save people about 4 hours of work using a rudimentary search function, as I had to do.
For a layperson who wants to save a few hundred, I think it's perfectly fine if they educate themselves about the search function and feature articles. That way, they at least understand the purpose of what they're doing.
And the time it takes is also reasonable, considering that we are answering the questions in this forum for free and in our free time,
. To avoid wasting any more of this valuable time, I'm here to help!
