unfug-1
Joined: 07/26/2005 Posts: 22 Karma: +2 / -6 Location: Köln
08-02-2006, 2:59 Subject: Diagnostic Cable: Which One is Best? |
What kind of diagnostic cable do I need for a Bora manufactured in 2001-06?
Thank you very much.
Translated on 26-09-2026, 11:22.
Ross-Tech-Support Profi-Schrauber
08-02-2006, 5:54 Subject: Diagnostic Cable: Which One is Best? |
Your Bora uses only a single K-line for diagnostics, and if you don't need to cover any other vehicles, an interface from the KEY series would be the right choice for you.
You can find this, for example, at RKS in their online shop.
KEY-COM (also known as Semiprofessional Diagnostic System EOBD/OBD2 KKL (RS232))
KEY-USB (also known as Semiprof. Diagnostic System EOBD/OBD2 KKL (USB))
The price includes a VAG-COM license, which is valid for current versions (currently 512.2).
P.S.: Possibly, in your future posts, you should use the forum search and/or the technical articles, because, for example, these questions have already been answered sufficiently.
Translated on 26-09-2026, 11:24.
bastion Blaumann
08-02-2006, 12:41 Subject: Diagnostic Cable: Which One is Best? |
Can this diagnostic system read out and modify parameters for all VAG vehicles with KKL and CAN interfaces?
Translated on 26-09-2026, 11:25.
mullemaus Guest
09-02-2006, 2:36 Subject: Diagnostic Cable: Which One is Best? |
Translated on 26-09-2026, 11:27.
bastion Blaumann
09-02-2006, 8:29 Subject: Diagnostic Cable: Which One is Best? |
I was just thinking of something else related to  .
But why is my question Oscar-worthy?
09-02-2006, 8:31 Subject: Diagnostic Cable: Which One is Best? |
bastion wrote: | I had something else in mind regarding Kennfelder. |
Okay, then explain what you meant, and maybe we can help you.
bastion wrote: | But why is my question Oscar-worthy?  |
Because you could have already found all of this information in the product description of the KEY-Interfaces...
Translated on 26-09-2026, 11:28.
bastion Blaumann
09-02-2006, 8:41 Subject: Diagnostic Cable: Which One is Best? |
I asked about CAN and KKL because I read that there is a USB connection for all VAG vehicles. I couldn't tell from the paragraph whether this only referred to the connector.
By "parameter fields," I mean dynamic self-calibration, torque control, quantity control, soot reduction, injection quantity, etc.
I don't plan to change those values just to turn my 90hp AHU into a "totally awesome tuning machine." It should be able to reach 300,000 km and that's good enough  .
Translated on 26-09-2026, 11:29.
Rudi Guest
09-02-2006, 10:22 Subject: Diagnostic Cable: Which One is Best? |
You cannot edit this type of characteristic fields with this tool.
Rudi
Translated on 26-09-2026, 11:30.
bastion Blaumann
09-02-2006, 10:27 Subject: Diagnostic Cable: Which One is Best? |
Reading is enough for me.
Joined: 04/12/2002 Posts: 18119 Karma: +801 / -0 Location: St.Gallen 2018 Volkswagen T6
09-02-2006, 10:32 Subject: Diagnostic Cable: Which One is Best? |
Again: VAG-COM is NOT a chip tuning system  .
Profile PM WWW Garage |
Rudi Guest
09-02-2006, 10:46 Subject: Diagnostic Cable: Which One is Best? |
Reading is the first step of editing  .
Rudi
